Material lab
dakiru
Material lab
Post by dakiru » Mon Sep 28, 2009 6:27 am
Hi guys. I've prepared few materials lately. And before uploading to matDB I would like to ask you for suggestions on making them better :) Comments a critics are very welcome
Problem: When I pack the material in Indigo and then want to use it here what I get:
Error: There was an error with the scene file: failed to load XML doc from path 'E:\_res\materials\redwood.pigm': Error document empty. (Line 0, column 0.)
Solved by unpacking the .pigm and using the .igm instead. Is it the only way?
Blender 2.49b
Blendigo 2.2.1
Indigo 2.2.1 x64
Re: Material lab
Post by Borgleader » Mon Sep 28, 2009 6:41 am
Yeah I'm not sure you can use the .pigms straight away yet as they are basically a compressed "folder", but I think Ono mentionned he might make that possible later on (by probably making indigo unpack the material internally or something).
dakiru
Re: Material lab
Post by dakiru » Mon Sep 28, 2009 6:51 am
Borgleader wrote:Yeah I'm not sure you can use the .pigms straight away yet as they are basically a compressed "folder", but I think Ono mentionned he might make that possible later on (by probably making indigo unpack the material internally or something).
Aha, so in this case I can do nothing with it. ok :)
dakiru
Re: Material lab
Post by dakiru » Mon Sep 28, 2009 7:23 am
Second one - wall base
Re: Material lab
Post by Borgleader » Mon Sep 28, 2009 7:30 am
Very nice, both of them :) Got more? :wink:
dakiru
Re: Material lab
Post by dakiru » Mon Sep 28, 2009 7:43 am
Borgleader wrote:Very nice, both of them :) Got more? :wink:
:D yup, asphalt, please
with 12mm bump
with 6mm displacement
Do you think it's ok, that I used phong with exponent map for the asphalt? And not a blend of phong and oren-nayar?
Re: Material lab
Post by Borgleader » Mon Sep 28, 2009 8:21 am
I think the result is quite satisfying as it is, I guess you could always try the other alternative and compare? Or just submit both and bump your way to #1 matDB contributor ;)
dakiru
Re: Material lab
Post by dakiru » Mon Sep 28, 2009 8:43 am
Borgleader wrote:I think the result is quite satisfying as it is, I guess you could always try the other alternative and compare? Or just submit both and bump your way to #1 matDB contributor ;)
:lol:
I would like #1 material quality more :mrgreen:
dakiru
Re: Material lab
Post by dakiru » Mon Sep 28, 2009 8:59 am
Phong/Oren-Nayar blended with blend map. Is it better?
Re: Material lab
Post by Borgleader » Mon Sep 28, 2009 9:41 am
Could you somehow render both side by side? In one scene, because the first render seems a little washed out compared to this one so it's hard to tell which one is "better"
dakiru
Re: Material lab
Post by dakiru » Mon Sep 28, 2009 10:11 am
Left - Phong with exponent map / Right - Phong/Oren-Nayar with blend map
Re: Material lab
Post by Borgleader » Mon Sep 28, 2009 10:23 am
Personally I like the material version on the right better than the one on the left, although both of them are very nice :)
dakiru
Re: Material lab
Post by dakiru » Mon Sep 28, 2009 10:28 am
Borgleader wrote:Personally I like the material version on the right better than the one on the left, although both of them are very nice :)
So, the right one then, seem to be more realistic for me too :)
And...
...rough stucco
Re: Material lab
Post by Borgleader » Mon Sep 28, 2009 10:53 am
Noyce!
dakiru
Re: Material lab
Post by dakiru » Mon Sep 28, 2009 1:18 pm
During the mat upload I've got this message:
We're sorry, but something went wrong.
We've been notified about this issue and we'll take a look at it shortly.
