dakiru
by dakiru » Mon Sep 28, 2009 6:27 am
Hi guys. I've prepared few materials lately. And before uploading to matDB I would like to ask you for suggestions on making them better
Comments a critics are very welcome
Problem: When I pack the material in Indigo and then want to use it here what I get:
Error: There was an error with the scene file: failed to load XML doc from path 'E:\_res\materials\redwood.pigm': Error document empty. (Line 0, column 0.)
Solved by unpacking the .pigm and using the .igm instead. Is it the only way?
Blender 2.49b
Blendigo 2.2.1
Indigo 2.2.1 x64
- redwood_preview_scene.jpg (78.41 KiB) Viewed 6100 times
by Borgleader » Mon Sep 28, 2009 6:41 am
Yeah I'm not sure you can use the .pigms straight away yet as they are basically a compressed "folder", but I think Ono mentionned he might make that possible later on (by probably making indigo unpack the material internally or something).
dakiru
by dakiru » Mon Sep 28, 2009 6:51 am
Borgleader wrote:Yeah I'm not sure you can use the .pigms straight away yet as they are basically a compressed "folder", but I think Ono mentionned he might make that possible later on (by probably making indigo unpack the material internally or something).
Aha, so in this case I can do nothing with it. ok
dakiru
by dakiru » Mon Sep 28, 2009 7:23 am
Second one - wall base
- base_preview_scene.jpg (84.94 KiB) Viewed 6078 times
by Borgleader » Mon Sep 28, 2009 7:30 am
Very nice, both of them
Got more?
dakiru
by dakiru » Mon Sep 28, 2009 7:43 am
Borgleader wrote:Very nice, both of them
Got more?
yup, asphalt, please
- with 12mm bump
- asphalt_preview_scene.jpg (101.91 KiB) Viewed 6079 times
- with 6mm displacement
- asphalt_disp_preview_scene.jpg (137.27 KiB) Viewed 6077 times
Do you think it's ok, that I used phong with exponent map for the asphalt? And not a blend of phong and oren-nayar?
by Borgleader » Mon Sep 28, 2009 8:21 am
I think the result is quite satisfying as it is, I guess you could always try the other alternative and compare? Or just submit both and bump your way to #1 matDB contributor
dakiru
by dakiru » Mon Sep 28, 2009 8:43 am
Borgleader wrote:I think the result is quite satisfying as it is, I guess you could always try the other alternative and compare? Or just submit both and bump your way to #1 matDB contributor
I would like #1 material quality more
dakiru
by dakiru » Mon Sep 28, 2009 8:59 am
Phong/Oren-Nayar blended with blend map. Is it better?
- asphalt_disp_blended_preview_scene.jpg (121.2 KiB) Viewed 6057 times
by Borgleader » Mon Sep 28, 2009 9:41 am
Could you somehow render both side by side? In one scene, because the first render seems a little washed out compared to this one so it's hard to tell which one is "better"
by Borgleader » Mon Sep 28, 2009 10:23 am
Personally I like the material version on the right better than the one on the left, although both of them are very nice
dakiru
by dakiru » Mon Sep 28, 2009 10:28 am
Borgleader wrote:Personally I like the material version on the right better than the one on the left, although both of them are very nice
So, the right one then, seem to be more realistic for me too
And...
...rough stucco
- preview_scene.jpg (89.9 KiB) Viewed 6037 times
by Borgleader » Mon Sep 28, 2009 10:53 am
Noyce!
dakiru
by dakiru » Mon Sep 28, 2009 1:18 pm
During the mat upload I've got this message:
We're sorry, but something went wrong.
We've been notified about this issue and we'll take a look at it shortly.
