for Indigo 1.1.14
download exporter:
Pc Version
Mac Version
(or below)
PC version contains plugins for R10 and R9. (R10 users will have to rename the "cindigo1.1.14.cdl_R10" to "cindigo1.1.14.cdl")
Make sure you have the newest version of quicktime installed!
Good beginner tutorials can be found here (german and english, a bit outdated)
1.1.14 changelog:
* reworked export routine. in extreme cases up to 10x faster export(even more if you heavily use instances. xml generation that is, mesh export is as fast as ever)
* a few little bugfixes
* improved instance handling (MUCH faster, better).
* very detailed console output with lots of infos.
1.1.14 known issues:
* i actually forgot the little bugfixes
* instances inside instanced objects will be ignored (this is going to be fixed)
exactly 160.000 instances, each 28.05 million polygons.
making a total of 4.889.187.200.000 polygons (4.8 trillion polygons).
for the large version click on the image.
Do you like Cindigo?
If you think its valueable software, please feel free to donate.
Please split the donation in two and donate the other half to Indigo.
