Cindigo 1.1.14 - "instancing terror!"
Post by fused » Sat Nov 08, 2008 8:17 am
Cindigo 1.1.14
for Indigo 1.1.14
download exporter:
Pc Version
Mac Version
(or below)
PC version contains plugins for R10 and R9. (R10 users will have to rename the "cindigo1.1.14.cdl_R10" to "cindigo1.1.14.cdl")
Make sure you have the newest version of quicktime installed!
Good beginner tutorials can be found here (german and english, a bit outdated)
1.1.14 changelog:
* reworked export routine. in extreme cases up to 10x faster export(even more if you heavily use instances. xml generation that is, mesh export is as fast as ever)
* a few little bugfixes
* improved instance handling (MUCH faster, better).
* very detailed console output with lots of infos.
1.1.14 known issues:
* i actually forgot the little bugfixes :)
* instances inside instanced objects will be ignored (this is going to be fixed)
exactly 160.000 instances, each 28.05 million polygons.
making a total of 4.889.187.200.000 polygons (4.8 trillion polygons).
for the large version click on the image.
Do you like Cindigo?
If you think its valueable software, please feel free to donate.
Please split the donation in two and donate the other half to Indigo.
Post by pixie » Sat Nov 08, 2008 9:04 am
Which kind of instance are? Cinema or cindigo's one?
Post by fused » Sat Nov 08, 2008 11:35 pm
In the above renderings i uses Cindigos instances, because i needed to include an external .ply file.
When you are instancing C4D objects, it doesnt matter if you use C4D's or cindigos instances, internally they are handled the same way.
When it comes to heavy instancing, one should use cindigos, because of the memory C4Ds instances use (they actually duplicate the object in memory, imagine what happens if you try to make 100 instances of a 1million poly mesh).
Post by pixie » Sun Nov 09, 2008 1:08 am
One might use the display tag :)
Post by fused » Sun Nov 09, 2008 3:31 am
what for? :?
Post by PureSpider » Sun Nov 09, 2008 7:25 am
For not displaying the instances that are still in the memory ;)
Post by zeitmeister » Sun Nov 09, 2008 11:51 pm
Great Job, as always!
Instances are working very well here; even rotated by XPresso … wonderful.
Textures don't have to be situated in the same folder as the models.
Polygon selections and multi-materials are supported … this fuckin rocks!
fused, are there any other mapping functions supported than UV-mapping?
manitwo
Post by manitwo » Sun Nov 09, 2008 11:57 pm
this is awsome fused :shock: !
Post by fused » Mon Nov 10, 2008 2:29 am
thx :)
zeitmeister wrote:Great Job, as always!
all other mapping types are supported.
Post by fused » Mon Nov 10, 2008 8:29 am
pc version added.
iacx
Post by iacx » Mon Nov 10, 2008 11:14 am
Thanks Fused :D
tungee
Post by tungee » Mon Nov 10, 2008 1:55 pm
Thanx fused!
Camox
Post by Camox » Tue Nov 11, 2008 2:01 am
GREAT , thnx fused ! :D
Juniorsatan
Post by Juniorsatan » Tue Nov 11, 2008 10:54 am
the new default settings in the export window are so comfortable!
Thanks for that minor modulation.
Looking foward to following improvements and features :)
Rafaello
Post by Rafaello » Thu Nov 13, 2008 9:08 am
hello fused, thanks for your hard work.
I was playing yesterday with a scene that worked fine in 1.1.13 PC versions of Indigo and Cindigo, but when I switched to 1.1.14 Indigo crashed with some of the instanced objects while other instances didn't send error message, Indigo said that it couldn't load a mesh that indeed didn't exist in the meshes folder.
can you check this?, all objects with instance problem were imported.
Thanks again.
