exit portal
9 posts • Page 1 of 1
metapixel
exit portal
Post by metapixel » Mon Jan 28, 2008 10:57 pm
Hi, I just wanted to share with all this a simple test that shows how important the use of the exit portal. :D
psor
Post by psor » Mon Jan 28, 2008 11:07 pm
Thanx! 8) ;)
take care
psor
"The sleeper must awaken"
surreal
Post by surreal » Tue Jan 29, 2008 7:46 am
How do i use an Exit portal?
*Edit Nm i figured it out!
Good to know thanks!
metapixel
Post by metapixel » Tue Jan 29, 2008 8:47 am
Hi, surreal
very simple, just create a box in Max with size of the window and apply the modifier "exit portal" and voilà! :D
Kosmokrator
Post by Kosmokrator » Tue Jan 29, 2008 9:11 am
thnx to suv to implement it so good via max exporter...btw...an bug or neseccery bad thing is the direction of light is not the same after the exit portal apply.... :wink:
i think Ono know about this is not something new!!!
Post by Kram1032 » Tue Jan 29, 2008 9:47 am
a box?
Usually, a plane is enough...
The normal should point through the window, inside.
Though, there're some problems: For example, if you have a veranda or any kind of outdoor models, they wont be rendered ;)
Post by pixie » Tue Jan 29, 2008 10:16 pm
Kram1032 wrote:a box?
Do a bigger box then ;-)
filippo
Post by filippo » Tue Jan 29, 2008 10:27 pm
Post by Kram1032 » Wed Jan 30, 2008 2:49 am
Yeah, you can do a bigger box (or plane...)
The geometry should:
  • be as simple as possible
  • perfectly go over the whole "hole"
  • have it's normals pointing in the direction the light is supposed to go.
If you let holes, you'll see black frames (at least when using BiDir)
If you make it too big (for example a big cube over the whole scene), the time increase will be far too minimal.
If the geometry is very complex, it's not as efficient.
If the normals point in the wrong direction, no light will come through them. They'll render as black walls (at least with BiDir)
