[Tutorial]Compositing your render/scene
I've seen some discussion about compositing techniques around the forum and thought I'd make a little tutorial.
The tutorial goes over three methods:
The alpha method - how to make an alpha render and use photoshop to put in a background
Environment maps - what they do
Image Planes - a cheat for getting an easy background and reflections without post-processing.
Enjoy!
Enjoy!
- House_env.jpg (67.49 KiB) Viewed 45222 times
- Tutorial_compositing.pdf
- (819.22 KiB) Downloaded 2859 times
- Doug Armand
Re: [Tutorial]Compositing your render/scene
Very nice, professional and useful tutorial.
Doug
Doug Armand
Doug Armand
- Borgleader
I massively approve of this tutorial
- Doug Armand
I massively approve of your approvalBorgleader wrote:I massively approve of this tutorial
Doug
Doug Armand
Doug Armand
I massively approve of... pie?
- fenerolina
Very good tutorial Soup! Thanks.
big THX Soup!
I too approve of this tutorial.
Very clear and usefulSoup wrote:I've seen some discussion about compositing techniques around the forum and thought I'd make a little tutorial.
Enjoy!
Many thanks for this neat tutorial!
Very useful!
Very useful!
Visit my website!
http://www.fairview-3d.com Studio 3D
Hi
+1 for this helpful tutorial. Precise and Concise.
Dear all,
I'd like to render an object and composite it in a HDR environment. The problem is, I would like the object to cast shadows on my envmap's flat ground (concrete floor in a business district surrounded by skyscrapers)
In 3DSMax, which i used several years ago, you can define a kind of "Matte/Shadow" material. This is a very special material that is rendered as a semitransparent shadow composited with the background.
For instance, you can do stuff like that:
http://forums.3dtotal.com/attachment.ph ... 1244270455
I don't like the solution that consists in re-modelizing the floor, as this will not connect well with the other parts of the scene.
Regards,
Etienne
Regards,
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
Do you think about something like this
I simply rendered a version with a white floor to get the shadows on "pure" white (tonemapping ist the hkey here!).
Then and cut the Objects out by a separate Alpha pass.
composing back in Photoshop for the final result
The image that is used for your objects in the compositing was rendered without floor, right? Then your render on white floor is used only to apply the shadws?
In that case it should work for me. I'll try that!
Etienne
Etienne
Jeff Hammond
the method deemed a cheat seems the best way to go for me.. i've tried the other two with mixed results..Soup wrote:I've seen some discussion about compositing techniques around the forum and thought I'd make a little tutorial.
Enjoy!
this tut gave me the idea of the image plane and it makes a lot of sense.. at the very least, you can actually see how things are going to line up prior to rendering.. everything else is too much guess work..
thanks for the tutorial
