by Whaat » Tue Nov 03, 2009 7:23 am
We need a really good stainless steel (for appliances) material in the database. Here's what I have so far. It seems decent but I'm sure it could be improved. Also, maybe someone could do some test renders by applying the material in a nice kitchen model or something.
Please improve this material if you can.
BTW...I don't know why there's this weird diamond pattern on the highlight.
- stainlessSteel2.png (305.27 KiB) Viewed 7252 times
- StainlessSteel2.pigm
- (600 Bytes) Downloaded 324 times
psor
by psor » Tue Nov 03, 2009 7:42 am
I'd say the pattern is based on the same issue I've reported
here.
take care
psor
"The sleeper must awaken"
by Whaat » Tue Nov 03, 2009 9:18 am
Yeah...I knew I saw that pattern somewhere before...needs to be fixed. Any progress on this ono?
Here's another version of the material with uniform bump instead of brushed.
- stainlessSteel3.png (300.16 KiB) Viewed 7207 times
- StainlessSteel3.pigm
- (572 Bytes) Downloaded 319 times
by OnoSendai » Tue Nov 03, 2009 10:08 am
psor wrote:I'd say the pattern is based on the same issue I've reported
here.
take care
psor
Actually I think it's a bump mapping artifact.
psor
by psor » Tue Nov 03, 2009 2:49 pm
That might be possible Nik. It could also be something you did to the Phong lobe,
as it's also there if no bump map is being used. And I haven't seen that on a
Specular nor Lambert nor Oren-Nayar yet.
edit: I'm wrong it's the bidirectional PT again.
take care
psor
Doug Armand
by Doug Armand » Tue Nov 03, 2009 5:04 pm
Heres an attempt at it. It uses a bump map I did in Pshop for the scratches - not sure how well it will wrap. It's also a bit on the large size
- Brushed_Stainless_Steel.jpg (84.39 KiB) Viewed 7133 times
Its a blend of CR.nk, NI.nk and MO.nk. Tried to upload it to the material database but I kept getting errors so here it is:
Doug
Doug Armand
by Whaat » Tue Nov 03, 2009 5:08 pm
nice, doug!
Doug Armand
by Doug Armand » Tue Nov 03, 2009 6:15 pm
Whaat wrote:nice, doug!
Thanks
I finally managed to upload it to the Material Database - it's called 'Brushed Stainless Steel'
Doug
Doug Armand
by zeitmeister » Wed Nov 04, 2009 6:09 am
"5Mo"?
by CTZn » Wed Nov 04, 2009 6:58 am
1 octet = 1 byte
5Mo = 5MB
by Borgleader » Wed Nov 04, 2009 7:16 am
CTZn wrote:1 octet = 1 byte
5Mo = 5MB
Yeah, he wrote it in french thats all
Jambert
by Jambert » Wed Nov 04, 2009 7:57 am
Borgleader wrote:CTZn wrote:1 octet = 1 byte
5Mo = 5MB
sorry
, it's 5MB
by zeitmeister » Thu Nov 05, 2009 12:55 am
Aaaaaalright!
What causes the size exactly, the scratch map, if it is a texture? This is a very nice material, and perhaps we can find a way to slim the texture a little bit?
Jambert
by Jambert » Thu Nov 05, 2009 1:34 am
yep, texture could be smaller, I generaly work with arroway so 5Mb is realy small to me
I tried to upload galery but it didn't work?!
