Blender light exporting problem!!!
Whenever I hit Blendigo to export under file>export>Blendigo, and then the scripts page comes up, then I hit export scene, and this window comes up, and says "scene must contain at least one light." I tried all I could, I got all I need to use Indigo, the scripts and everything, and installed everything, but I cant export anything! Help! in the file attachment there is a screenshot of what comes up when i hit "export scene."
- heres what comes up.
- Indigo problem.JPG (74.03 KiB) Viewed 4597 times
- joegiampaoli
The only lamp that directly works, is a sun. To activate it, you need to go to the environment tab and select "Sun and Sky" in the drop down menu.
If you don't want to use a sun to enlighten your scene, you need to build a mesh and give it an "emitter" material in blendigo.
The light will only flow in the directions of your normals. It wont glow in the other direction.
