[REQ] Render Names
Should Indigo saved igi's and png's starting with the scene name and with incremental numbers? (e.g. cupcaustics_1.png, cupcaustics_2.png)
Yes
38
93%
No
3
7%
Total votes: 41
Post by OnoSendai » Tue Jun 26, 2007 10:06 pm
suvakas wrote:Why so complicated?
It's up to exporter really... -o whatevername.png is defined by exporter. So it can be a scene name or a custom name. No -o parameter means random numbers.
If we could get the same custom name option for igi, then it would be enough.
Ok it's on the TODO list.
Post by Zom-B » Tue Jun 26, 2007 11:14 pm
suvakas wrote:If we could get the same custom name option for igi, then it would be enough.
Please don't forget the exr's to have a name option too...
The easiest way would be to trigger by -o the same name for all the output (png, igi & exr).
Post by suvakas » Tue Jun 26, 2007 11:21 pm
ZomB wrote: The easiest way would be to trigger by -o the same name for all the output (png, igi & exr).
That would be very good.
Post by CTZn » Wed Jun 27, 2007 8:52 pm
+1
deltaepsylon
Post by deltaepsylon » Thu Jun 28, 2007 5:13 am
Yay, my plan worked :D :D
And those 'random numbers', i beleive they are the Seed for the thread random number generator. So they still are random :D
Post by Zom-B » Thu Jun 28, 2007 5:19 am
deltaepsylon wrote:And those 'random numbers', i beleive they are the Seed for the thread random number generator. So they still are random :D
if you sort your render folder by name you will see, that the newer renderings have biger number than the older ones, so their not really random, but perhaps add a random number...
deltaepsylon
Post by deltaepsylon » Fri Jun 29, 2007 6:51 am
But thats because (methinks) Indigo's random thingy is seeded with numbers that have to do with the date, which is always increasing AFAIK
Post by suvakas » Fri Jun 29, 2007 7:01 am
It's the number of seconds since 1970.
ThatDude33
Post by ThatDude33 » Fri Jun 29, 2007 1:39 pm
suvakas wrote:It's the number of seconds since 1970.
One... two... three... four... :D
I like this idea.
Matt B. >>Maya To Indigo<<
arneoog
Post by arneoog » Tue Jul 03, 2007 9:10 am
Sh*t! Suvakas, you're right! :lol:
Post by Kram1032 » Wed Jul 18, 2007 11:05 pm
tested :P
1970Sec.zip
Zipped Excel that includes a seconds counter :D
(1.6 KiB) Downloaded 393 times
deltaepsylon
Post by deltaepsylon » Tue Jul 24, 2007 11:44 pm
lol
Post by Zom-B » Fri Feb 15, 2008 9:23 pm
I would like to bump this thread since I having a problem realizing a "project".
My Idea is to use Indigo also on some friends computers to share rendertime over different Computers.
So I put all stuff needed on a USB Stick, Indigo + Scenefile and a bat file to start rendering in console mode, and one to resume this rendering.
The Idea is to start once the rendering on my Friends Computer, and then after igi file is saved for the first time, stop it.
Now I use the bat file for resume rendering and modify it to always save to a named igi file, and always resume from this file.
Now I could simply put this bat file into his Autostart, and each time the Computer is on, Indigo resumes my rendering...
This is the basic Idea, but the only thin needed is some little coding work from you Ono, for a feature requested since -o is an option...
