Cindigo 0.8 - beta 2
Locked
kadajawi
Post by kadajawi » Mon Jun 04, 2007 10:20 pm
okazaky wrote:Would it be possible to create some kind of material preview for cindigo? That would be a very nice feature :)
Aren't they working on a material editor/preview/something already? Something like the stuff Kerkythea or Maxwell have? I think then it would be unneccessary, and I believe doing something with Cindigo would mean a lot of work.
okazaky
Post by okazaky » Tue Jun 05, 2007 6:36 am
Cool, didn't hear about that. A "real" material preview would be much nicer than a fake or half-baked one in cindigo, that's right ;)
Post by Zom-B » Tue Jun 05, 2007 8:30 am
If Somebody is interested, here my Material Preview Scene.
Its based on Indigo Primitives, and quite fast.
runing on my AMD x2 3.800 on thwo threads with ~85k muatations per second, a 15min rendering of a cr.nk is attached.
<scene>
<renderer_settings>
   <width>480</width>
   <height>480</height>
   <bidirectional>false</bidirectional>
   <hybrid>true</hybrid>
   <metropolis>true</metropolis>
   <num_threads>2</num_threads>
   <polarisation>false</polarisation>
   <super_sample_factor>1</super_sample_factor>
   <save_igi>true</save_igi>
</renderer_settings>
	<camera>
	   <pos>0 -5.2 2.5</pos>
	   <up>0 0 1</up>
	   <forwards>0 1 -0.3</forwards>
	   <focus_distance>2.000000</focus_distance>
	   <aspect_ratio>1</aspect_ratio>
	   <aperture_radius>0.001</aperture_radius>
	   <sensor_width>0.036</sensor_width>
	   <lens_sensor_dist>0.08</lens_sensor_dist>
	   <white_balance>D65</white_balance>
	</camera>
	<tonemapping>
        <reinhard>
            <pre_scale>3</pre_scale>
            <post_scale>1</post_scale>
            <burn>4</burn>
        </reinhard>
	</tonemapping>
<rectanglelight>
		<pos>0 0 7.5</pos>
		<width>17.5</width>
		<height>10</height>
		<spectrum>
			<blackbody>
				<temperature>6500</temperature>
				<gain>1</gain>
			</blackbody>
		</spectrum>
</rectanglelight>
<!-- Material of the Ball -->
	<material>
		<name>mat_test</name>
		<phong>
			<nk_data>nkdata/cr.nk</nk_data>
			<exponent>1000</exponent>
		</phong>
	</material>
	<!-- MATERIAL sphere -->
	<sphere>
	   <center>0 0 1</center>
	   <radius>1</radius>
       <material_name>mat_test</material_name>
	</sphere>
	<!-- Ground Material -->
    <material>
      <name>ground</name>
   	  <diffuse>
	    <colour>0.8 0.8 0.8</colour>
	  </diffuse>
    </material>
	<!-- Ground Plane  -->
	<plane>
	   <normal>0 0 1</normal>
	   <dist>0</dist>
   	   <material_name>ground</material_name>
	</plane>
	<!-- Back Plane  -->
	<plane>
	   <normal>0 -1 0</normal>
	   <dist>-8</dist>
	</plane>
</scene>
15min rendering
Post by Kram1032 » Tue Jun 05, 2007 8:33 am
I'd like to have infinite planes working with BiDir, again!!!
Post by Zom-B » Wed Jun 06, 2007 3:13 am
17) The Tile settings & texture Offset values for UVW mapped Textures don't get exported.
18 ) You sure know, but the normal length normalising, that Indigo does for you, totally sucks for big Meshes!!!!!
80MB normalize for ~26min using only one core :cry: My Hair2mesh2Indigo test are some freakin pain in the ass...
Post by Zom-B » Thu Jun 07, 2007 1:16 am
I just found a workaround for the normalization issue, and wanted you guys to know:
just reopen the exported OBJ Files in C4D and export them as Wavefront OBJ.
File size gets reduced to ~65% of the original filesize, and Indigo don't need to normalize anything.
(Tiling of UVW mapped Textures can be assigned then too :wink: )
BTW:
My request for multiple Blending of already blended materials is obsolete!
It already works in the current version... my fault :oops:
Post by fused » Thu Jun 07, 2007 1:23 am
cool, does normal smoothing work?
if not, this is kind of senseless...
Post by Zom-B » Thu Jun 07, 2007 1:28 am
fused wrote:cool, does normal smoothing work?
good question dude... :?:
I used this workaround for a hair2mesh carpet of 125000 small pyramids,
with disabled normal smoothing...
but it should be easy to test... reporting back in few minutes ;)
**EDIT**
I just checked....for the obj files exported by C4D using Wavefron OBJ doesn't work :cry:
Post by fused » Thu Jun 07, 2007 2:06 am
hmmm... stupid c4d...
kadajawi
Post by kadajawi » Thu Jun 07, 2007 2:10 am
Mh, just an idea. Maybe create a field in the texture tag where you can enter the XML code of a material? That way you have more flexibility if neccessary. Ok, you could edit that into the exported XML file, but you have to do that everytime you export, so it's a bit troublesome.
Post by Zom-B » Tue Jun 12, 2007 10:46 pm
How about using the C4D OBJ export for all meshes that have normal smoothing disabled... 8)
Post by fused » Wed Jun 13, 2007 12:04 am
sry for not updating the plugin, im pretty busy being ill with a very painful desease... (very very very painful)
ill probably dont have to work for the next two weeks (this and the next), maybe if i feel better next week ill have very much time for the exporter.
well... im off, getting some painkillers because there will be lunch in half an hour.
cya
kadajawi
Post by kadajawi » Wed Jun 13, 2007 12:23 am
Oh, gute Besserung und lass dir Zeit, Cindigo funktioniert ja schon relativ gut :)
Ah, and cancel my last request, I'd rather have this:
http://www2.indigorenderer.com/joomla/f ... sc&start=0
:D
Marcofly
Post by Marcofly » Wed Jun 13, 2007 7:43 pm
gute besserung!! :wink:
Phoenix
Post by Phoenix » Thu Jun 14, 2007 12:29 am
Auch von mir gute Besserung!
Kurier Dich erstmal richtig aus!
Locked
