mrCarnivore
by mrCarnivore » Sun Mar 11, 2007 5:40 am
I'm trying to render a glass of milk since it seems like these are kind of in nowadays.
I would like to achieve a result like this:
http://www2.indigorenderer.com/joomla/f ... light=milk
But I have some problems: I followed the modeling instructions for fluid in a glass from here:
http://www2.indigorenderer.com/joomla/f ... .php?t=637
And I used the milk material from here:
http://www2.indigorenderer.com/joomla/f ... 88eb0#9018
The glass material I use is this:
<medium>
<name>GlassMedium</name>
<precedence>10</precedence>
<basic>
<ior>1.50</ior>
<rgb>
<rgb>0.5 0.5 0.5</rgb>
</rgb>
</basic>
</medium>
<material>
<name>GlassMaterial</name>
<specular>
<internal_medium_name>GlassMedium</internal_medium_name>
</specular>
</material>
My problem is this: The bottom of the glass looks way too white which is very unrealistic. Also the milk is just too white...
But have a look yourself:
- milk and bottom of glass way too white.
- milk_too_white.jpg (65.4 KiB) Viewed 3682 times
- Glass model I used.
- glass_model.jpg (53.56 KiB) Viewed 3682 times
neepneep
by neepneep » Sun Mar 11, 2007 5:57 am
How big is your model in blender?
mrCarnivore
by mrCarnivore » Sun Mar 11, 2007 6:19 am
When I press N in blender, the dimensions of the left glass are:
DimX = 0.20
DimY = 0.20
DimZ = 0.34
so it seems to be 20 cm long doesnt it? shall I reduce the size?
EDIT: The result doesn't really change when I reduce the size to DimX = 0.08..
by OnoSendai » Mon Mar 12, 2007 6:26 pm
Make sure the precedence of the glass medium is higher than that of the milk medium.
8bstudio
by 8bstudio » Mon Mar 12, 2007 9:00 pm
Try to use for the glass these settings:
<medium>
<basic>
<ior>1.50</ior>
<rgb>
<rgb>0.0 0.0 0.0</rgb>
</rgb>
</basic>
</medium>
mrCarnivore
by mrCarnivore » Mon Mar 12, 2007 9:17 pm
@OnoSendai: With higher you mean lower numer, right? So the glass medium is supposed to have a lower precedence number than milk?
@8bstudio: I think making the glass even whiter would be counterproductive, wouldn't it?
by OnoSendai » Mon Mar 12, 2007 9:27 pm
heh, no, when i say higher, i mean a higher value.
Yes, i know this contradicts the CS convention, but meh.
nik
8bstudio
by 8bstudio » Mon Mar 12, 2007 9:29 pm
mrCarnivore wrote:I think making the glass even whiter would be counterproductive, wouldn't it?
I saw in many post that completly transparent glass have rgb absorption coefficient = 0 0 0. I you use a rgb 0.5 0.5 0.5 maybe is grey glass!
In my test for glass with rgb 0 0 0 normaly I get good result! Try to see my last post for example
http://www2.indigorenderer.com/joomla/f ... 2&start=30
You can try!
by OnoSendai » Mon Mar 12, 2007 9:34 pm
absorption 0.5 0.5 0.5 is very slight absorption (mean path length on the order of 2m)
8bstudio
by 8bstudio » Mon Mar 12, 2007 9:43 pm
Maybe I wrong with glass rgb = 0 0 0 because with Indigo v0.6 I used those!
I try me too with 0.5 0.5 0.5!
by OnoSendai » Mon Mar 12, 2007 9:50 pm
The units changed from Indigo 0.6 to 0.7.
The units of absorption changed from mm^-1 to m^-1
mrCarnivore
by mrCarnivore » Mon Mar 12, 2007 9:54 pm
Thx for the help. Hope I'm seeing better results with the higher precedecy value.
