I have seperated this discussion from the Simple Renderings Thread...
I am not able to use the black and white picture for displacement definition. Can anyone help me with the correct parameters and the necessary steps with SkIndigo? (testmodel attached)
Thank you...
Cardboard displacement map
- displ_cardboard.zip
- (13.71 KiB) Downloaded 309 times
- ninopiamonte
Re: Cardboard displacement map
I use texture maps (as a material) instead of displacement or clip map.
And I just only used bumps.
Here, I attached the .skp file and the two texture maps.
Sorry if it's not about the displacement. Because of no interest, as long as the render is a bit realistic.
- cardboard.zip
- (495.61 KiB) Downloaded 314 times
