This looks like something in your scene has a blank name? It might be a material, texture, object, mesh - it's not possible to tell from the console view. It might also be an un-assigned texture or something like that. Double check your mesh+materials setup - if the problem persists, try to trim down the scene to just the minimum that causes the error and post it here so that I can analyse it.Alain wrote:Blendigo seems not to work for me as well.
Blender 2.58.1
Indigo RT 3.0.14 64 Bit
Win 7 64 Bit
What do I do wrong ?
Kind regards
Alain
Blendigo (for Blender 2.58) 3.0.10.1
Re: Blendigo (for Blender 2.58) 3.0.10.1
I'd suspect a texture.
All other things (Objects, Meshes, Materials) have a name assigned by default.
However, assume you have created a material and texture (type : image) channel for that material. In the Indigo specific material panel you need to specify the texture to be used for a Indigo material slot, e,g, Material Color or Bump etc.
Then you decide to rename the texture. You have to reassign the texture to the Indigo material slot.
If you went directly from renaming the texture to the render panel you'll get exactly that error.
Then you decide to reassign the texture and try to render the thing again and you'll get the same error because you choose an Image texture but forgot to actually load an image
Thanks, I guess I cleaned the texture part now.
But there is another error, see attachment: What means "Object does not have duplis" ?
Kind regards
Alain
Kind regards
Alain
Great thank you, will try itPolinalkrimizei wrote:...had to make one cut in the back. Not the most logic/useful workflow...
I had same error with a with a 2.49 scene open with 2.5? You have to re-path all your textureAlain wrote:Blendigo seems not to work for me as well.
Blender 2.58.1
Win 7 64 Bit
Kind regards
Alain
I already did, but now I have another error (see above).Jambert wrote:I had same error with a with a 2.49 scene open with 2.5? You have to re-path all your textureAlain wrote:Blendigo seems not to work for me as well.
Blender 2.58.1
Win 7 64 Bit
Kind regards
Alain
Kind regards
Alain
sorry I remember, I deleted all your texture and changed there directory to be sure it didn't use the old path (because it did!!!). You can make test using one object/mat/texture on an another layer.Alain wrote:I already did, but now I have another error (see above).Jambert wrote:I had same error with a with a 2.49 scene open with 2.5? You have to re-path all your textureAlain wrote:Blendigo seems not to work for me as well.
Blender 2.58.1
Win 7 64 Bit
Kind regards
Alain
Kind regards
Alain
Ok, I'll test that.
Other question:
Is there no material Indigo-Preview in Blender ?
And is there no Indigo-Texture Preview in Blender ?
Kind regards
Alain
Other question:
Kind regards
Alain
OK, now it exports without an error.
But Indigo RT doesnt start. Yes, I've set the path to indigo.exe.
I've have to start Indigo RT manually and load the *.igs file there.
Kind regards
Alain
Kind regards
Alain
You did check "AutoStart" right below the field for the Indigo executable path ?Alain wrote:. Yes, I've set the path to indigo.exe.
Alain
Yes I did, I installed the "normal" version of Indigo now and it starts now.
But I still have some questions:
-Is there no material and no texture - preview in Blendigo ? Or do I have to set materials like blind cow ?
-What does the error message "object has no duplis" exactly mean ? I have 2 particle systems in my scene (objects distributed over a plane), could that be the reason ?
I still have that error: Can somebody help me please ? I'm very confused that not even such basics do work...
Kind regards
Alain
Kind regards
Alain
Win 7 64 Bit, 8 GB RAM, Geforce GTX 480, Blender 2.62, Indigo RT Trial, Blendigo 3.2.12.0
another one...
... what is wrong ?
Edit:
It happens when I activate Aperture Diffraction. Could it be a bug ?
Kind regards
Alain
Edit:
Kind regards
Alain
Hi Alain,
Both those errors could be Blendigo bugs - I'll add them to the list of things to check & fix.
Cheers,
Doug,
Cheers,
Doug,
And what about material- and texture preview ?
I can't believe such a basic function is not implemented in Blendigo.
I hope I did something wrong
Kind regards
Alain
Kind regards
Alain
Before, it was possible to export preview scene. Now you can't export from blendigo but you can still use preview scene and try your material.Alain wrote:And what about material- and texture preview ?
Kind regards
Alain
- previewscene.igs
- (19.5 KiB) Downloaded 331 times
