Hell and help :)
Hell and help :)
ok here is the problem i have 3ds max 2011 and indigo 2.6.1 beta (i think) now i just cant seem to figure out how to work with IES light i created a target. photometric light selected web distribution,selected IES profile and nothing...then i thought id try with emitter material but i just cant seem to find where to select ies in the material editor or what kind of map to add well dont blame the newbie
cant someone point to me what to do with screen shots if posible i have looked at this http://www.indigorenderer.com/forum/vie ... =19&t=7430 but where are emitter atributes anyway if anyone can halp me out would be cool
Re: Hell and help :)
lol good to know i was about to smash my head on the keyboardENSLAVER wrote:I could be wrong, but I'm not sure the max plugin has IES functionality yet.
Hi dtoxic,
Maxigo has IES support (just tested and works fine here). Steps you describe seem to be correct too.
Did you have your camera and/or tonemapping set up correctly? Maybe your light was too weak or smth?
Try with a single photometric light and reinhard tonemapping.
Ha, I was looking in the wrong spot for them too, I kept looking in the emitter material options.
Here's I got them to work -
Create > lights > photometric lights > target or free
Modify panel > general > Light distribution (type) > Drop down to Photmetric Web, then choose an IES file.
Here are two IES files that I know work w/indigo, use these to test =)
http://dl.dropbox.com/u/6928552/01.ies
http://dl.dropbox.com/u/6928552/02.IES
thx people got it
keyboard survived as did my head
thx again
I am sorry but "where" exactly?
I follow this:
http://www.indigorenderer.com/documenta ... ies-lights
and that:
and again that:
http://www.indigorenderer.com/forum/vie ... 0&start=15
and finally that:
http://www.indigorenderer.com/forum/vie ... =9&t=11889
If i create a photometric light in 3ds max and add an IES files i have a Null result. (not exactly i have 1 pixel white where i have the center of my light
even if i tweak my exposure control.
even if i choose an other ies file from http://www.indigorenderer.com/dist/ies-profiles.zip
If i create a plan with a indigo material i don't find where i need to put the link to the IES file.
So i probably misunderstanding something.
If i use a geometry to distribute the light, like a tube for example.
can i link an igm with an IES definition?
If it's correct (it seems no but..) can you send me the link to the technical documentation, i don't know how to do that in this kind of igm:
Thank a lot by advance for your help
I follow this:
and that:
and again that:
and finally that:
<scenedata>
<material>
<name>lamp</name>
<diffuse>
<albedo>
<constant>
<rgb>
<rgb>0.5 0.5 0.5</rgb>
<gamma>2.2</gamma>
</rgb>
</constant>
</albedo>
<base_emission>
<constant>
<rgb>
<rgb>150000.0 150000.0 150000.0</rgb>
<gamma>1</gamma>
</rgb>
</constant>
</base_emission>
<layer>0</layer>
</diffuse>
</material>
<layer_name>
<layer_name>Layer-0</layer_name>
<layer_index>0</layer_index>
</layer_name>
</scenedata>
errare humanum est
Find here a 3D and an IES file from Phillips with all the stuff we need for that
http://www.ecat.lighting.philips.com/l/ ... 958003_eu/
The ligth is distributing by smalls polygone squares.
With a color temperature at 3000 K; it provide 2800 Lm and 95 Lm/W Luminous efficacy.
errare humanum est
