Maxigo Scatter
Maxigo comes with a unique scatter feature that takes an object and scatters it over the surface of another. It uses Indigo Instances so it uses a lot less memory than simply duplicating objects.
To use, apply this modifier to the object you wish to scatter, and press Pick.. to choose the surface to scatter onto.
Density: The amount of scattered objects.
Seed: Used to change to a different randomized set.
Clumps Count: Uses the density amount and creates clumps of this amount.
Radius: The radius of the clumps.
A use of Maxigo scatter
