Some new shader stuff:
Post by OnoSendai » Sun Nov 29, 2009 3:16 pm
Access to the world space normal of the surface fragment from inside a shader:
<diffuse>
			<albedo>
        <shader>
          <shader>
            <![CDATA[
						def eval(vec3 pos) vec3 :
                  vec3(
                    doti(normalWS()),
                    dotj(normalWS()),
                    dotk(normalWS())
          </shader>
        </shader>
      </albedo>
		</diffuse>
Access to the zenith angle of the incident and scattered rays, allowing effects like colour-changing paint:
<material>
		<name>default</name>
		<phong>
			<diffuse_albedo>
        <shader>
          <shader>
            <![CDATA[
                  lerp(
                    vec3(1.0, 0.0, 0.0),
                    vec3(0.0, 1.0, 0.0),
                    thetaMax()
          </shader>
        </shader>
      </diffuse_albedo>
      <exponent>
        <constant>
          10000.0
        </constant>
      </exponent>
		</phong>
  </material>
I'll probably release this stuff after 2.2 stable is done.
Re: Some new shader stuff:
Post by lycium » Sun Nov 29, 2009 3:36 pm
rock on :) i've been wanting to write some ISL shaders for a while...
psor
Post by psor » Sun Nov 29, 2009 4:53 pm
Looking good! I'm wondering if we can create "dirt" shader in the near future too. ;o))
take care
psor
"The sleeper must awaken"
Post by OnoSendai » Sun Nov 29, 2009 5:48 pm
Hi, Psor, what do you mean by a dirt shader?
Post by lycium » Sun Nov 29, 2009 5:52 pm
i think he means something like what you had on your blog (which i miss btw, those rainbow tests etc were awesome), the "dust" shader which blended in some constant "dirty" colour depending on y component of the normal (since dust mostly falls downwards).
Post by CTZn » Sun Nov 29, 2009 6:17 pm
Yeepee !
Sometimes distance/curvature based shaders are refered to as dirt shaders, because they affect small features more. Curvature shaders could be used as blend maps to figure weared corners and stuff... but I'm not sure what psor is refering to :)
I understand the second pic visually (and that's quite enough) but I'd like to understand more... is this involving the incoming light direction ? If that's the case then the scene is not self-explanatory (light position), either what I don't get the subtlety...
Anyways... very cool stuff Ono !
Post by OnoSendai » Sun Nov 29, 2009 6:41 pm
CTZn: Basically the colour changes as the view direction of a surface moves from the normal direction to grazing direction.
Post by neo0. » Sun Nov 29, 2009 7:34 pm
OnoSendai wrote:CTZn: Basically the colour changes as the view direction of a surface moves from the normal direction to grazing direction.
So like iridescence?
Stromberg
Post by Stromberg » Sun Nov 29, 2009 7:40 pm
Realy cool :)
I see dirt shader like some sort of ambient occlusion, that you could blend and make dirt texture maps appear where the ao is... would be cool to have :)
Post by OnoSendai » Sun Nov 29, 2009 7:50 pm
Yeah. I think that's how colour-changing car paint is made.
djegoo
Post by djegoo » Mon Nov 30, 2009 1:59 am
wohooooo this efect on this teapot was exactly what i was desperately trying to do tonight by noobishly blending materials (yeah i m not expert :oops: ) and no succes!!!!
aaay i m so impatient to have this kind of shader
juan_irender
Post by juan_irender » Mon Nov 30, 2009 2:25 am
Perfect, Ono! Every add you make to ISL is very, very convenient for Indigo.
Many thanks!
C4D R18 Studio user
Blender user :D
Post by CTZn » Mon Nov 30, 2009 4:34 am
It's so obvious what the shaders are doing now... :oops: I know them !!! Dunno what happened yesterday, brain@sunday or something close for sure.
zeitmeister, is your request: closest to shaded point ?
ie: very close is very dark and vice-versa. Could be used for menisque creation (use a flat water surface in a glass, apply distance shader as displacement. Same applies to displace the soil around a tree), some weathering effects (as AO pass) and more SFX.
Hang on: light gray on all meshes with unform backround lighting, tonemap and go ! You know that already zeitmeister :)
psor
Post by psor » Mon Nov 30, 2009 2:41 pm
Stromberg wrote:Realy cool :)
Yupp, that's how I would explain it too. Maybe a dirt shader needs a few more options tho.
Cause I'd need it to be possible to have irregularities instead being as smooth as AO.
I've to admit that I haven't used a dirt shader for years now as my work was mainly archviz
and they like there stuff clean. :mrgreen: :wink:
I guess today you call it just AO and that's it. I'm a bit ol' school. ;o))
take care
psor
Reason: Images removed because of auth request from external link
Stromberg
Post by Stromberg » Mon Nov 30, 2009 8:56 pm
Thanks Psor, for explaining this :)
And it's what i tought, but maybe with a turbulence option aswell, very usefull :D
