Maxigo 2.0.12a (updated on 17.oct 2009)
Post by suvakas » Wed Oct 14, 2009 7:31 am
Hey all,
I think it's time to bring Maxigo out of beta.
If there are no major bugs found, then I can upload it to the main 3ds Max download page.
One of the new features in this release is material presets. You can now create some basic material types with only a few mouse clicks. There are currently 5 different categories available: Glass, Liquids, Plastic, Metal and Other. Presets are loaded dynamically from .igm files inside Maxigo/Presets folder so they are easily extendable.
There is also one new preview model called "Waves". I think it could be good for testing SSS materials. (see the image below).
[update - Maxigo 2.0.12a]
I hopefully fixed the bug where material parameters appeared under Utilities panel after loading a scene.
You can download Maxigo from this link:
Maxigo 2.0.12a
Changes in v.2.0.12a:
* fixed - Indigo material parameters appeared under Utilities panel after loading a scene
* fixed - Linked materials can be used inside Indigo Blend material (nested blends still not supported)
Changes in v.2.0.12:
* added - Presets for common material types (Glass, Liquid, Metal, Plastic)
* added - New material preview model - "Waves" (good for testing SSS materials)
* added - Image refresh interval to Render Material dialog
* added - material file download is cancelled after closing the online MDB window
* fixed - dotNet error after closing the online MDB window during download
* fixed - error when using Indigo Emitter material inside Indigo Blend material
* fixed - material preview when linking new material over mat. that has emission enabled
* fixed - Exit Portal warning dialog
* fixed - Reseting IndigoMain material
* fixed - Storing .ini values after clean installation (fixes empty Indigo and temp.path issue)
* changed - Bump values are presented in millimeters now
* changed - Menu Item handling improved
zed_pmd
Re: Maxigo 2.0.12
Post by zed_pmd » Wed Oct 14, 2009 7:42 am
Thanx suvakas ;)
Re: Maxigo 2.0.12
Post by fused » Wed Oct 14, 2009 7:59 am
Sounds sick, Suv :)
Congratz!
zed_pmd
Re: Maxigo 2.0.12
Post by zed_pmd » Wed Oct 14, 2009 8:31 am
Suvakas, you can idea of what way to hasten the export of scenes from Max? It takes a little too slow :(
Re: Maxigo 2.0.12
Post by suvakas » Wed Oct 14, 2009 9:04 am
zed_pmd wrote:Suvakas, you can idea of what way to hasten the export of scenes from Max? It takes a little too slow :(
It's a bit slow since the exporter is written in Maxscript and script is quite slow when dealing with large amounts of vertecies and faces.
But the good news is, that I'm already working on some C++ code to speed up the process. So the next gen Maxigo will be a lot faster. (read next gen and not next version :wink: )
zed_pmd
Re: Maxigo 2.0.12
Post by zed_pmd » Wed Oct 14, 2009 9:10 am
Good tidings;) In that case, i'm waiting ;)
zed_pmd
Re: Maxigo 2.0.12
Post by zed_pmd » Sat Oct 17, 2009 3:37 am
Suvakas - maxigo 2.0.12 generates strange error after loading the scene:
When the material switches from the diffuse to phong etc. everything back to normal.
Re: Maxigo 2.0.12
Post by suvakas » Sat Oct 17, 2009 3:40 am
Ups.. indeed.. thanks for the report.
I will fix it asap.
zed_pmd
Re: Maxigo 2.0.12
Post by zed_pmd » Sat Oct 17, 2009 3:41 am
No problem :wink:
Re: Maxigo 2.0.12a (updated on 17.oct 2009)
Post by suvakas » Sun Oct 18, 2009 3:43 am
@zed_pmd
I think I fixed it. I updated the link in the 1st post of this thread.
Could you please check if it still happens ?
zed_pmd
Post by zed_pmd » Sun Oct 18, 2009 4:12 am
Hi Suvakas, thanx for quick update ;)
There is no error already.
Post by suvakas » Sun Oct 18, 2009 4:18 am
zed_pmd wrote:Hi Suvakas, thanx for quick update ;)
So you can confirm, that the 2.0.12a fixed it for you?
If it did, then I can update the main download link too.
zed_pmd
Post by zed_pmd » Sun Oct 18, 2009 4:44 am
Yes, I confirm. Maxigo 2.0.12a no longer has this bug.
Post by suvakas » Sun Oct 18, 2009 6:14 am
Thank you zed !
Kosmokrator
Post by Kosmokrator » Sat Oct 24, 2009 10:09 pm
thnx a lot suv!!!
