Black Glass
- pixie
Black Glass
Despite having a blue sky the glass goes black no matter what...
- glass.zip
- glass.pigs
- (22.33 KiB) Downloaded 338 times
- glass.jpg (49.82 KiB) Viewed 34551 times
Re: Black Glass
The edges of the glass look extremely sharp?
Re: Black Glass
Make sure there's a gap between ground and glass.
- pixie
Re: Black Glass
It has, and still nukesOnoSendai wrote:Make sure there's a gap between ground and glass.
This time no bidir
- glass.jpg (68.92 KiB) Viewed 34527 times
- pixie
Re: Black Glass
Aren't they lovely?ZomB wrote:nice to see the missing caustics here...
Phong seems to have some relevance to it...
Re: Black Glass
wasn't this a low mncr issue. try raising your setting.
Re: Black Glass
where's the indigo FAQ?
- Borgleader
Re: Black Glass
the first entry has to be "why is my light not working in daylight?" (answer: the former is insignificantly bright. see also, "why is my fart not audible against thunder?")
sorry for derailing this thread a bit, just wanted to point out that new users would greatly benefit from such a FAQ
- pixie
Re: Black Glass
UPDATED: Latest bidir on bigger scale
some renders exposing it further
MCNR was increased to 100000
The problem remains the same on 1.1.18
If I enlarge the scene (cm become now dm) then the glass becomes more transparent which IMO is odd since a thicker glass should be less transparent...
- Global Scale: cm -> dm
- mlt bidir.jpg (94.33 KiB) Viewed 34304 times
- mlt bidir
- mlt bidir.jpg (140.55 KiB) Viewed 34420 times
- mlt
- mlt.jpg (147.61 KiB) Viewed 34422 times
Re: Black Glass
I can see caustics, they just look like a fart compared with the mitchell netravali ehanced spots.ZomB wrote:nice to see the missing caustics here...
Normals seem busted on the last shots (triangulated top edge ?), check the geometry again !?
You mean the ground I guess... there's no phong in the glass material, right ?pixie wrote: Aren't they lovely?
- pixie
Re: Black Glass
But they are way bigger ifMLT is to be used, AFAIK there's no problem with geometry, It's modeled from a cylinder, with all the normals as they should be.CTZn wrote:I can see caustics, they just look like a fart compared with the mitchell netravali ehanced spots.ZomB wrote:nice to see the missing caustics here...
It is of some relevance to the glass if you add phong to it, it becomes darkerCTZn wrote:You mean the ground I guess... there's no phong in the glass material, right ?pixie wrote: Aren't they lovely?
Re: Black Glass
+1lyc wrote:where's the indigo FAQ?
