Renderer's Rings
WytRaven
Renderer's Rings
Post by WytRaven » Fri Jul 17, 2009 4:36 pm
Final render:
F Stop: 64
Exposure: 1/4s
ISO: 100
Tonemapping: Camera - DSCS315, EV -1.0
White Balance: D55
Lit by 4 mesh emitters and an HDRI environment map
Indigo: 2.0.10, 20Kspp
Worklog here
WR - Renderer's Rings - 17-07-2009.jpg (223.39 KiB) Viewed 8023 times
Re: Renderer's Rings
Post by OnoSendai » Fri Jul 17, 2009 6:45 pm
Very cool image.
Maybe some aperture diffraction glare would look good, or maybe that's frowned upon for such shots.
WytRaven
Post by WytRaven » Fri Jul 17, 2009 7:00 pm
OnoSendai wrote:Very cool image.
I am using aperture diffraction just not with an obstacle map other than the generated blades as every time I try to use additional map the whole image gets blurred. However, I will have a play and see how I go.
Doug Armand
Post by Doug Armand » Fri Jul 17, 2009 7:43 pm
Wow - nice image. It's come a long way from your first tests.
No crits... :wink: except it looks a little soft? Maybe aperture diffraction is cause?.
Apart from that it's excellent. Diamonds look great
Edited :
Hope you don't mind but I worked it over a bit in PShop. I might have got a bit carried away with the bloom :oops:
Doug
Doug Armand
WytRaven
Post by WytRaven » Fri Jul 17, 2009 9:14 pm
Doug Armand wrote:I might have got a bit carried away with the bloom
might...? :lol:
Doug Armand
Post by Doug Armand » Fri Jul 17, 2009 10:38 pm
:D :D
Doug
Doug Armand
Post by zeitmeister » Fri Jul 17, 2009 10:39 pm
Really great materials, Wyt!
Post by CTZn » Sat Jul 18, 2009 12:19 am
Well done !
Godzilla
Post by Godzilla » Sun Jul 19, 2009 3:31 am
oh god doug, please never use lens flare again =/
WytRaven
Post by WytRaven » Sun Jul 19, 2009 4:06 pm
Doing another render now with a few tweaks. Double the res, no aperture diffraction, and exponent on the gold and silver materials much higher. Will see how it turns out.
Godzilla
Post by Godzilla » Sun Jul 19, 2009 4:11 pm
Try it with a matt, colored backdrop, HDRI image, and a close-up so that one ring is mostly in focus and the other isn't.
Just my suggestion for setting up the scene :wink:
WytRaven
Post by WytRaven » Sun Jul 19, 2009 4:30 pm
Godzilla wrote:Try it with a matt, colored backdrop, HDRI image, and a close-up so that one ring is mostly in focus and the other isn't.
Noted, appreciated, and ignored. :lol:
Seriously though thanks for the input zilla but the scene composition I am completely happy with. I am just striving to get the best output from the current setup now ;)
Godzilla
Post by Godzilla » Sun Jul 19, 2009 5:12 pm
It's ok I understand. I'm just sharing how I would set up the scene :) . You have your own personal tastes and I have mine :wink:
Stromberg
Post by Stromberg » Mon Jul 20, 2009 1:43 am
Sure looks nice :)
Nothing to critic on it's perfect :)
WytRaven
Post by WytRaven » Mon Jul 20, 2009 2:10 am
Thx Stromberg :)
Ok Zilla I have decided to give your idea a go and bring the point of focus forward about 2mm. This causes the front of both rings to be in focus and the rear of both to begin fuzzing out. Not sure how it will go but I will at least try it.
However, at 5.76MP (1800x3200) with 2x super sampling this scene takes a hell of a lot longer than the original (900x1600). Currently looking at ~130 hours to reach 20K spp.
