Error: Failed to load texture
10 posts • Page 1 of 1
Silmä
Post by Silmä » Fri Jun 26, 2009 8:04 am
Is Indigo supposed to give this kind of error when the texture files are on different disk drives than indigo itself, or am I doing something wrong?
This happened when i installed the latest indigo and blendigo, and tried to re-render one of my older scenes to see the difference in render times. The file paths on blendigo are correct, but somehow it seems to screw them up during export.
benn
Re: Error: Failed to load texture
Post by benn » Fri Jun 26, 2009 1:04 pm
Silma: You need to put the textures on the same drive as the scene - i'll add it as a fix for the next version of Blendigo.
Doug Armand
Post by Doug Armand » Fri Jun 26, 2009 5:31 pm
I'm getting same thing and the image file is in the same drive/folder as the saved blender file.
Error: SceneLoaderExcep: Failed to load texture 'c:\users\dougar~1\appdata\local\temp\..\..\..\..\..\..\..\f:Dougs Stuff\3D\Blender Scenes\Iceberg\waterripple8et.jpg': Error loading texture file 'c:\users\dougar~1\appdata\local\temp\..\..\..\..\..\..\..\f:Dougs Stuff\3D\Blender Scenes\Iceberg\waterripple8et.jpg' - file not found
a work around for the moment is to save the .igs file and then edit it and provide the full path to the image file.
Doug
Doug Armand
WytRaven
Post by WytRaven » Fri Jun 26, 2009 6:26 pm
Doug Armand wrote:a work around for the moment is to save the .igs file and then edit it and provide the full path to the image file.
That's what I have to do with the Mac version at the moment too.
Doug Armand
Post by Doug Armand » Fri Jun 26, 2009 6:57 pm
Actually I just tried to render an older complex scene and this is a real problem. When you have loads of textures to replace and the blender file is huge it's a mammoth task to replace them all. Needs to be fixed asap. :(
Doug
Doug Armand
Doug Armand
Post by Doug Armand » Sat Jun 27, 2009 8:54 pm
Well two days and no fix? :evil:
come on guys this is now commercial software and needs a quick fix for this and soon.
I don't want to have to hand edit every time I render and this is getting real annoying. I'm surprised many others haven't complained about it. :?
Doug
Doug Armand
Polinalkrimizei
Post by Polinalkrimizei » Sun Jun 28, 2009 12:14 am
No batch yet, but having the same problem! :(
Everything is on the same disk, but I get the same error message!
Doug Armand
Post by Doug Armand » Tue Jun 30, 2009 5:22 pm
Still waiting for a fix guys - whats the hold up? :evil:
Doug
Doug Armand
Post by OnoSendai » Tue Jun 30, 2009 5:29 pm
Hi Doug, we should have a fix for this tomorrow. Sorry about the inconvenience.
Doug Armand
Post by Doug Armand » Tue Jun 30, 2009 5:35 pm
Thanks for the quick reply Ono - information is always welcome :D
Doug
Doug Armand
