[BUG] Glossy transp mat getting way too dark
Post by PureSpider » Tue May 26, 2009 10:46 pm
While rendering my jug for the jug competition, I noticed that with later versions than 1.1.14 (which I usually use for rendering), glossy transparent materials get very dark.
This is the material code:
    <medium>
        <name>MedSimple_Glossy_Glass</name>
        <precedence>10</precedence>
        <basic>
            <ior>1.41000</ior>
            <cauchy_b_coeff>0.00000</cauchy_b_coeff>
                <rgb>
                    <rgb>0 0 0</rgb>
                    <gamma>1</gamma>
                </rgb>
        </basic>
    </medium>
    <material>
        <name>Simple_Glossy_Glass</name>
        <glossy_transparent>
            <internal_medium_name>MedSimple_Glossy_Glass</internal_medium_name>
            <exponent>
                <constant>100</constant>
            </exponent>
        </glossy_transparent>
    </material>
See attached picture for reference.
Polinalkrimizei
Re: [BUG] Glossy transp mat getting way too dark
Post by Polinalkrimizei » Wed May 27, 2009 7:35 am
Yes I am having the same problem! What's wrong?
Post by fused » Wed May 27, 2009 7:47 am
its a bug, obviously. well have to wait for it to be fixed...
Polinalkrimizei
Post by Polinalkrimizei » Wed May 27, 2009 8:47 am
Is there a chance that it is gonna be fixed for the free versions of indigo? PLEASE Ono...
Post by suvakas » Wed May 27, 2009 9:03 am
Same tonemapping, same scale, same everything?
I'm asking cause i've not seen this kind of issue before and tonemapping seems to be different for 1.14 version (on your image i mean). Like linear vs camera tm on others or smth like that.
[edit]
Tested the glossy material you posted on my water jug with 2.06. I see nothing wrong with it. Seems perfectly fine to me. :roll: So I'd say it could be your scene setup, maybe?
Post by CTZn » Wed May 27, 2009 9:31 am
Is it really a bug or a correction ?
Refering to the rendered tone only, that could as well be a correction... We just don't know, do we ?
If it's a bug then it's aknowledged by now. But if that's a correction then it is wanted, in wich case you want to correct your materials in turn ;)
Post by PureSpider » Wed May 27, 2009 10:11 am
suvakas wrote:Same tonemapping, same scale, same everything?
TM and scene setup it 100% the same!
Maybe it depends on the viewing angle?
Any clue what is causing it though?
Post by fused » Wed May 27, 2009 10:17 am
render mode? mlt/pt? bidir on/off?
Post by CTZn » Wed May 27, 2009 11:08 am
Intersecting meshes, or meshes below the allowed distance ? Too thin wall ?
You could compare a specular and a glossy materials using the same medium side by side with different Indigo versions... say, to spheres primitives, to elude geometric options.
Post by PureSpider » Wed May 27, 2009 11:18 pm
fused wrote:render mode? mlt/pt? bidir on/off?
PT BiDir in all cases
CTZn wrote:Intersecting meshes, or meshes below the allowed distance ? Too thin wall ?
Nope, ray nudge distance is okay, even tried it with 10^-9; got black artifacts everywhere, problem remains the same.
€dit: Look at the floor of the glass... looks okay there in all cases; it only gets black when the viewing angle is more steep...
Post by CTZn » Wed May 27, 2009 11:37 pm
Well, we are not supposed to play with the ray nudge distance. Distance between surfaces should simply be above 0.2mm while using the standard r_n_d setting, like Ono says.
In all cases I think we should allow the doubt on the cause for that difference in tones, just because we ignore the technical reasons behind.
Post by PureSpider » Wed May 27, 2009 11:56 pm
Just checked, the minimum wall thickness is 0.175 cm in all cases on the glass.
Post by CTZn » Thu May 28, 2009 12:08 am
The wall is allright then. Still, you didn't mention the floor/recipient distance. It could very well be above the minimal limits, if that matters. I'm just meaning to lead us to a maximized objectivity regarding the issue.
Edit: Extrapolating from what we know, if the distance for two objects when one at least uses a medium is below the minimum then perhaps the volume is considered open (I'm speculating). Opened volumes render darker iirc.
Post by PureSpider » Thu May 28, 2009 12:16 am
CTZn wrote:The wall is allright then. Still, you didn't mention the floor/recipient distance.
THAT was my first thought, too!
So I moved the glass up 1 cm to be sure and re-rendered - result is the same.
Post by CTZn » Thu May 28, 2009 2:13 am
okay
