Cindigo 2.0.X progress
Post by fused » Mon May 04, 2009 9:10 am
Hey all,
im working on the new Cindigo and while Cindigo 1.1.18 RC4 should work just fine with indigo 2.0 i feel that there is still lots room for improvement.
ill share the new stuff im working on here.
ive been working a bit on motion blur:
the old export routine works well in most cases, but there are some shortcomings:
- instances tend to get not exported correctly
- deformers arent working at all
- the way im doing it is horribly complicated
so i tried something different. its not perfect yet and i broke lots of things, amongst them:
- animation export
- material association to meshes
- motion blur
- material / setting seperation (will be removed anyway, it does not fit in what im planning to do)
fun with deformers:
i also moved the render settings object to the c4d render settings dialog (made it a video post plugin).
Re: Cindigo 2.0.X progress
Post by fused » Mon May 04, 2009 1:15 pm
some more progress...
- materials on meshes are being detected fine now
- i decided not to export c4d instances as instances in indigo anymore, because they arent even instances and by that you can use them to the fullest (the can be deformed, have different uvs, etc). use the indigo instance object instead
- material export is back
- code is much easier to read and understand now
- cindigo is usable again after breaking it completely :mrgreen:
Post by CTZn » Mon May 04, 2009 3:46 pm
Oh, Indigo 2 added motion blur...
Fun stuff fused :)
Post by PureSpider » Tue May 05, 2009 12:25 am
Post some screens of the new settings and whats changed in general please :)
Post by pixie » Tue May 05, 2009 1:08 am
PureSpider wrote:Post some screens of the new settings and whats changed in general please :)
Pretty please with sugar on top! =)
Post by fused » Tue May 05, 2009 2:25 am
for now, visaully nothing has changed, the render settings look the same, they're just in a different place.
only internal changes for now - im going deep tho ;)
Post by zeitmeister » Tue May 05, 2009 7:38 am
This looks great, fused!
Maybe you could think about an instance conversion? Like the material conversion?
I think that could make things easier...
Post by fused » Tue May 05, 2009 8:20 am
zeitmeister wrote:This looks great, fused!
... hm.
the cindigo instance object isnt allowed to be nested(you know... instance inside instance) while c4d instances are... that would not work out well. maybe, when i get the nested stuff working :)
Post by zeitmeister » Tue May 05, 2009 8:28 am
Oh, this is hard then.
I personally love nested instances and work with them as often as possible...
but I think when it's getting over to Indigo, collapsing and converting all of my objects is not the big problem.
Although it would be really nice to avoid this step... :-)
Post by fused » Tue May 05, 2009 8:34 am
zeitmeister wrote:Oh, this is hard then.
You will not have to collapse or convert anything, C4D instances are exported just fine, even deformed - just not as instances in Indigo but as meshes. :)
Post by pixie » Tue May 05, 2009 9:15 am
But they take a lot of time when in meshes... :(
Post by fused » Tue May 05, 2009 11:04 am
ive been working on some stuff today that was actually promised for the 1.1 stable.
im converting c4d lights now. area lights at least. they get exported as meshes with emitting materials (with the rgb color from the light object or, if a light tag is applied, with the settings from this).
i might also implement spot lights with a default IES, but i will have to export a small plane for it.
point lights, directional lights and the sqare spot will not be possible (are there sqare IES profiles? if yes, are they supported by indigo? if yes, i might add that too) and not be implemented.
Post by Zom-B » Tue May 05, 2009 4:51 pm
This sounds really great Yves!
fused wrote:i might also implement spot lights with a default IES, but i will have to export a small plane for it.
Hmmm.... how about not exporting just as "default" IES, but directly convert the spotlight to a fitting IES!
Since IES files are only renamed text files, with some "few" values and numbers it should be quite easy to generate some Spotlights by playing arround with IES Generator...
Some more infos about IES can be found here
Here you can find the File Format... and here some more explanations
Post by fused » Tue May 05, 2009 5:55 pm
ZomB wrote:This sounds really great Yves!
sounds like a nice idea, will look into that. but until then im just using the a default.ies :)
oh and btw: i added onmi lights as emitting spheres of 1cm in diameter. not really recommended to use tho :)
Post by zeitmeister » Tue May 05, 2009 8:00 pm
ROFL! A nice scene, with 6 to 7 omnis as fill-lights, HDRI and sunsky... :D
