Indigo 1.1.14
Indigo 1.1.14
Post by OnoSendai » Wed Nov 05, 2008 4:00 am
The big change here is the introduction of the BVH (Bounding volume hierarchy) to replace the BIH. The BVH is generally a lot faster in terms of rendering speed than the BIH (> 80% the speed of the kd-tree), while preserving the same low memory usage and build times of the BIH.
The BVH still builds low quality trees in some circumstances, resulting in low rendering performance , such as the Cornell box scene, but generally it's pretty fast. This will hopefully be fixed in future.
Let me know any performance results, especially comparing the BVH to kd-tree on different scenes.
Switching between the BVH and kd-tree will be done with the bih_tri_threshold setting. (Which is now a misnomer)
32 bit:
http://www.indigorenderer.com/dist/indigo_v1.1.14.zip
64 bit:
http://www.indigorenderer.com/dist/indi ... 1.1.14.zip
changelog:
1.1.14
* fixed fmod linking in ISL
* added OpenMP Dll + manifest to distributions
* replaced BIH with BVH
Post by Whaat » Wed Nov 05, 2008 4:20 am
Thanks ono!
Marcofly
Post by Marcofly » Wed Nov 05, 2008 4:23 am
thank you Ono! rendertime speed improvement sounds very interesting!! :D :D
Post by Zom-B » Wed Nov 05, 2008 4:24 am
Thanks Ono.... speedups are always very welcome :D
***EDIT***
OK, now I get it... so Heavy Poly (displacement+subdivision) will benefit from this...
Any numbers how much BVH is faster than BIH for rendering?!
Post by PureSpider » Wed Nov 05, 2008 4:30 am
<@PureSpider> will only the build speed be faster or render speed in general?
<+CTZn> both if I understood ok
<@OnoSendai> of what vs what?
<@PureSpider> BVH vs "normal" kd
<@OnoSendai> build is faster, render is slower
<@PureSpider> eeeeeh :@
<+CTZn> ah, necessarily slower ?
<@OnoSendai> yes
<+CTZn> ok, good to know
<@OnoSendai> ok, in some cases it may be faster
<@OnoSendai> render speed: kdtree > BVH > BIH
<@OnoSendai> mem usage: kdtree > BVH = BIH
Hope that got things clear :P
Post by Borgleader » Wed Nov 05, 2008 5:11 am
Should the exporters for 1.1.13 work with this build?
Camox
Post by Camox » Wed Nov 05, 2008 5:25 am
Thanks Ono ! :D
Post by CTZn » Wed Nov 05, 2008 5:28 am
Expectedly 100% borgleader
Pinko5
Post by Pinko5 » Wed Nov 05, 2008 8:15 am
wowwww tnx Master!!!
Luca. ;)
Post by Zom-B » Wed Nov 05, 2008 12:14 pm
ZomB wrote:Any numbers how much BVH is faster than BIH for rendering?!
My small 5Min Benchmark with some fancy displacement & subdivision was 2.4% faster for BVH than BIH... but BVH consumed about 7% more RAM (1.384GB vs 1.290 GB)
... so far my number crunching test.
Big Fan
Post by Big Fan » Wed Nov 05, 2008 4:34 pm
what happened to the clay material experiment?
postponed or scrapped? :roll:
vmuriel
Post by vmuriel » Wed Nov 05, 2008 4:48 pm
oooooooooh, again no linux release.
Post by fused » Wed Nov 05, 2008 5:11 pm
@ono: couldnt find out what the uv set name was, so i rendered it with SSS. im not even sure if there is any...
doubt this is of interest for you, but i find 60s for 28million poly very exciting :)
Building Mesh 'lucy.ply'...
14027870 vertices (321.072 MB)
28055737 triangles (749.169 MB)
BVH::build()
Calcing root AABB.
Done.
Root AABB min: (225.841080,-388.417145,-605.892822)
Root AABB max: (1155.670166,145.354340,991.145996)
Sorting...
Done (8.44906 s).
Allocating intersect triangles...
Done. Intersect_tris mem usage: 963.217 MB
Build Stats:
Total nodes used: 9408392 (574.243 MB)
Total tri indices used: 37624372 (143.526 MB)
Num sub threshold leaves: 9408272
Num max depth leaves: 120
Num cheaper no-split leaves: 0
Mean tris per leaf: 2.981991
Max tris per leaf: 5
Mean leaf depth: 23.645914
Max leaf depth: 63
Finished building tree.
Done Building Mesh 'lucy.ply'. (Time taken: 60.20800 s)
delle
Post by delle » Wed Nov 05, 2008 8:39 pm
Thank you Ono.
I wait for a new Indigo release as a child waits for Christmas... :lol:
Delle
filippo
Post by filippo » Wed Nov 05, 2008 11:17 pm
thaks ono!!!
filippo
