XP Home vs XP Professional
6 posts • Page 1 of 1
mild_mannered
Post by mild_mannered » Tue Jul 01, 2008 4:18 am
I have two computers, one with xp home , the other with xp pro. I'm trying to get blender-blendigo-indigo to work. The xp home seems to be ready to go, everthing seems fine. The xp pro is installed the same as far as I can tell, but when I click Export Scene, an error window pops up saying
"Indigo.exe has encountered a problem and needs to
close. We are sorry for the inconvenience."
If I go directly to the Indigo folder and double click the Indigo.exe icon the same error window pops up. Does anyone have an idea why I am getting this error? I'm crossing my fingers that its an easy fix. Thanks.
palawat
Post by palawat » Tue Jul 01, 2008 5:18 am
You probably need to update to SP2. I'm not sure. But I'm using XP Pro SP2 and it works fine here.
Hope this help.
Cheers,
mild_mannered
Post by mild_mannered » Tue Jul 01, 2008 7:50 am
I have SP2 but thanks or the suggestion.
zsouthboy
Post by zsouthboy » Tue Jul 01, 2008 7:52 am
It's not likely an OS problem - instead, a possible memory issue or your cpu in your pro box doesn't support SSE2 (although when that happens the error is different)
psor
Post by psor » Tue Jul 01, 2008 8:17 am
@mild_mannered
I could be wrong and I don't even know if it's still needed anymore, but it's
possible that your WinXP Professional needs some VC++ files tho.
Microsoft Visual C++ 2005 SP1 Redistributable Package (x86)
Microsoft Visual C++ 2008 Redistributable Package (x86)
Probably you'll just need the 2005 stuff and it's unlikely that it will harm
your PC. Hope this will help a bit. ;o))
take care
psor
"The sleeper must awaken"
mild_mannered
Post by mild_mannered » Thu Jul 03, 2008 6:40 am
that didn't change anything. But thanks. This really isn't a critical thing but I'd like to get it straightened out if anyone has anymore suggestions. I'd really be in a bit of distress if this was all i had but I'm going to be OK with it. Just got to get myself motivated to start a rendering to see what other problems you guys can help me with. Thanks
