Black spots which wont go away... Can someone help me? :(
11 posts • Page 1 of 1
iOnStallion
Post by iOnStallion » Tue Dec 04, 2007 2:15 am
Hi everybody,
im workin on a project for my graduation. But now some problems showed up and i dont know how to get rid of them... Its these black things on the picture i changed the mesh and subdivided it but nothing worked...
Can someone help?
Post by suvakas » Tue Dec 04, 2007 2:23 am
Hey.
Do you have normal smoothing on? If yes, then disable it and see if it helps.
Post by OnoSendai » Tue Dec 04, 2007 2:36 am
It also looks like it might be multiple faces with different materials sharing the same plane.
SmartDen
Post by SmartDen » Tue Dec 04, 2007 2:48 am
yes, it looks the same for me
iOnStallion
Post by iOnStallion » Tue Dec 04, 2007 3:03 am
i turned the phong tag of and remodelled the scene but there are still these things... i just dont understand that...
Woodie
Post by Woodie » Tue Dec 04, 2007 3:58 am
could you provide some more info? Software, exporter, versions? Maybe a file to look at?
Behrendt
Post by Behrendt » Tue Dec 04, 2007 4:03 am
Check your global scale multiplier!
Vanessa07
Post by Vanessa07 » Tue Dec 04, 2007 4:41 am
Try removing doubles??? :?
Pinko5
Post by Pinko5 » Tue Dec 04, 2007 5:06 am
Try to see if you have two identical objects one hide to camera but not hide to render...may be??....bye
Pinko. ;)
Post by CTZn » Tue Dec 04, 2007 5:20 am
If cleaning the shapes turns difficult, redo the problematic ones. If you don't mind you can post/pm the mesh in obj format and I'll check and clean if possible.
Post by Kram1032 » Tue Dec 04, 2007 8:43 am
For me, it looks like over-scalement or a too low ray-nudge-distance...
try to multiply that by ten or divide your scene-scale by the same :)
