CoolColJ
by CoolColJ » Fri Aug 17, 2007 12:36 pm
as it says - same settings but separate renders, pic says it all
used V0.9test 6
- BiD_MLT.JPG (16.53 KiB) Viewed 3159 times
- Bugged one
- BiDMLT_BUG.JPG (16.54 KiB) Viewed 3159 times
by Zom-B » Fri Aug 17, 2007 1:06 pm
Do you mean that both results were archived by rendering the same igs file two times???
attaching the scene would really help dude
CoolColJ
by CoolColJ » Fri Aug 17, 2007 1:22 pm
attached - make sure all files and folders are in the same directory.
This is how SKindgo exports em out
- Bug_testscene.zip
- (138.43 KiB) Downloaded 228 times
by OnoSendai » Fri Aug 17, 2007 4:33 pm
So... what's the bug?
CoolColJ
by CoolColJ » Fri Aug 17, 2007 4:40 pm
have a look at the position of the caustic on the bottom of the glass sphere
same scene, 2 different renders, it moved
possibly related to the Sun movement bug
by OnoSendai » Fri Aug 17, 2007 4:42 pm
That's not a bug, it's just an odd case of slow convergence. Let it render for longer.
Cire
by Cire » Fri Aug 17, 2007 6:14 pm
I think CoolColJ is referring to the 'caustic' ON the bottom of the sphere itself (I believe it's actually a reflection or refraction) . . . not the caustics on the floor beneath the sphere.
by OnoSendai » Fri Aug 17, 2007 6:21 pm
Cire wrote:I think CoolColJ is referring to the 'caustic' ON the bottom of the sphere itself (I believe it's actually a reflection or refraction) . . . not the caustics on the floor beneath the sphere.
That's what I'm referring to as well.
Cire
by Cire » Fri Aug 17, 2007 6:38 pm
Well then . . . that is as you said, an odd case of slow convergence.
by Zom-B » Fri Aug 17, 2007 6:57 pm
the problem is, that you can't reproduce this issue with the scene
I did 5 renderings for 45minutes each on 2x2ghz dualcore.
But I have to admit that since 0.9t1 reflections on specular materials need VERY long to convergence!
some wired
reflections stay for long time till they disappear (WinOSi Test Scene for example)
