The13Ronin
by The13Ronin » Sun Jun 03, 2007 9:33 pm
I'm using INDIGO 0.8 with the BLENDER 0.8 Exporter (before I was using V0.6, same problem).
The title states my problem:
The command line gives me the error ImageExcep: Failed to open "[RANDOM RENDER PGN NAME]"
I can't get the end result of my hard work
I'm desperate for help. Please someone...? Anyone...?
joegiampaoli
by joegiampaoli » Sun Jun 03, 2007 9:47 pm
Wow, this is new to me never heard of this issue....
Joe Giampaoli
My Indigo Gallery
neepneep
by neepneep » Sun Jun 03, 2007 10:27 pm
Have you tried using a different file format like JPG and see if that makes a difference?
The13Ronin
by The13Ronin » Sun Jun 03, 2007 10:44 pm
neepneep wrote:Have you tried using a different file format like JPG and see if that makes a difference?
Huh?
neepneep
by neepneep » Sun Jun 03, 2007 10:58 pm
...i didn't read the title - I thought it was trying to open a PNG file.
Okay, are you sure you have a /renders folder in your indigo directory?
The13Ronin
by The13Ronin » Sun Jun 03, 2007 11:40 pm
No I don't, am I required to make one?
by suvakas » Sun Jun 03, 2007 11:49 pm
Yep, that's where the rendered images are going.
Strange, that you don't have it. It should be there by default.
The13Ronin
by The13Ronin » Sun Jun 03, 2007 11:55 pm
I'll make one and post back the results. I'm not optomistic.
by Kram1032 » Mon Jun 04, 2007 12:05 am
I had that bug with 0.6, if I remember correctly..
after adding it, it worked fine.
None of the newer Versions had that missing folder...
by suvakas » Mon Jun 04, 2007 12:07 am
I guess you didn't unpack the indigo installation package correctly. The proper directory structure is already in the zip file you downloaded. Try to unpack it again.
The13Ronin
by The13Ronin » Mon Jun 04, 2007 12:10 am
Thanks, that fixed the original problem! But now I have a new one... MY IMAGE IS BEING RENDERED WHITE... Nothing... Just white... White all over... (And when I save a file it always and I mean ALWAYS saves into the correct folder but saves under the name DEFAULT, even when I change it under the export script). It doesn't look like this when I render with Blender. Argh! Why must I have all these problems!
Once again I plead for the help and compassion of anyone who may be able to lend a hand.
This problem is driving me nuts... I might try reverting back to V6 to see if I have the same problem.
by Kram1032 » Mon Jun 04, 2007 12:26 am
This sounds like a usual problem:
You don't have ANY lightsource in your scene.
It should be the same with 0.6 or with any other Inidigo Version.
The13Ronin
by The13Ronin » Mon Jun 04, 2007 12:29 am
Kram1032 wrote:This sounds like a usual problem:
But I have a lamp! Now the models showing up but my texture isn't showing up ARGH!
I have a model of Earth and I can see Earth but it appears as purple sphere instead of having the sea and land textures I attached to the sphere!
(The textured version is rendered by blender but not by Indigo?)
by Kram1032 » Mon Jun 04, 2007 12:36 am
Hum.... strange...
Which Exporter are you using?
What are your settings, to get the textures from Blender to Indigo?
Are the textures in the same folder as the .igs?
The13Ronin
by The13Ronin » Mon Jun 04, 2007 12:42 am
Kram1032 wrote:Hum.... strange...
Don't the textures export with the model?
I've just been using all default Indigo export settings and i'm using the Indigo Exporter for Blender V0.8.
