Altus from innoBright look like a very interesting denoiser!
2 posts • Page 1 of 1
Phoenix
Post by Phoenix » Wed Nov 04, 2015 4:32 am
Take a look at this: innoBright Altus
(And here are also some FAQ.)
Really great results in the examples they show.
Looks darned well and promising in my opinion.
Re: Altus from innoBright look like a very interesting denoi
Post by Zom-B » Wed Nov 04, 2015 5:52 pm
There has been a ton of denosing Papers released in the recent years, finally someone does read them :)
For me the input variables for this program are quite.... much!
You need two renders with different seed, and a crapton of Render Passes:
The Altus require two sets of inputs labeled with b0 and b1 rendered with different
sample seeds respectively.
The required AOVs are as follows:
RGB: This is the beauty render
ALB: This is an albedo AOV, unshaded texture AOV
VIS: This is the visibility of the geometry to the lights, a suitable AOV for this would be a
shadow AOV
NOR: Forward Facing Normals with bump map preservation
POS: World Position
CAU: Caustics AOV
By having two renderings you actually have twice the rendertime... having this doubled rendertime for your actual render should help denoising too ^^
I would love to see some denoise functionality directly in Indigo!
Something that does use such AOVs directly works in 32bit as a PostPro filter.
