Indigo Renderer 3.6.16 Beta Release
Post by OnoSendai » Tue Jun 18, 2013 3:41 am
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_3.6.16.2_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.6.16.2_Setup.exe
Indigo for Linux 32-bit:
IndigoRenderer_v3.6.16.2.tar.gz
Indigo for Linux 64-bit:
IndigoRenderer_x64_v3.6.16.2.tar.gz
Indigo for Mac OSX (10.6 - 10.8 ):
IndigoRenderer3.6.16.2.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.6.16.2_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.6.16.2_Setup.exe
Indigo RT for Linux 32-bit:
IndigoRT_v3.6.16.2.tar.gz
Indigo RT for Linux 64-bit:
IndigoRT_x64_v3.6.16.2.tar.gz
Indigo RT for Mac OSX (10.6 - 10.8 ):
IndigoRT3.6.16.2.dmg
Changelog:
3.6.16
* Fixed: Pick material and assign material don't work in conjunction.
* Copying any emission scaling from background settings to exit portal objects.
* Fixed sampling for env maps + exit portals so it is efficient again.
* Fixed jumping to end and clearing of the selection in render log.
* Fixed: Network client table isn't cleared on 'stop' then 'render'.
* Fixed crash on invalid shader parameter name.
* Fixed issue on OS X reading large IGIs.
* Fixed shader editor dialog resizing issue on OS X.
* Fixed: Alpha rendering renders background as alpha = 1 when there is no background material.
* OS X build is now signed.
* Updated bundled SkIndigo installer in Windows build to SkIndigo-3.4.19.
juan_irender
Re: Indigo Renderer 3.6.16 Beta Release
Post by juan_irender » Tue Jun 18, 2013 7:19 am
Thanks for the update, Ono!
Post by Oscar J » Tue Jun 18, 2013 11:32 am
I can't set the camera to focus on a certain object anymore. Hard to tell if it's a Blendigo or an Indigo bug though.
lape
Post by lape » Tue Jun 18, 2013 6:22 pm
thank you!
Post by pixie » Wed Jun 19, 2013 9:10 am
A big thanks! :)
Post by Oscar J » Thu Jun 20, 2013 8:03 am
"Invisible to camera" option seems to be out of function too - when I try to hide an emitter so that it just shows up indirectly in reflections - it still shows up to the camera.
Post by fused » Fri Jun 21, 2013 10:14 pm
Oscar J wrote:"Invisible to camera" option seems to be out of function too - when I try to hide an emitter so that it just shows up indirectly in reflections - it still shows up to the camera.
Hi Oscar
no, that's exactly how it's supposed to work.
It will be invisible directly to the camera but indirectly it will still be visible, in reflections for example.
Mor4us
Post by Mor4us » Sat Jun 22, 2013 12:44 am
Hi Oscar
I think you misunderstood oscar ;)
What you're describing is exactly what oscar wants, but the emitter is still visible (directly) to the camera.
Post by fused » Sat Jun 22, 2013 12:53 am
Mor4us wrote:
Hi Oscar
Oh, right, I misread that. Sorry :)
Will look into it.
Cheers!
Post by fused » Sat Jun 22, 2013 12:56 am
Oscar,
it seems to work here. Can you maybe provide a simple example scene that shows this problem?
Please note thta the emitter will show up when in *every* indirect situation. That means it will also be visible when viewed through a pane of glass, for example.
Post by Oscar J » Sat Jun 22, 2013 1:49 am
Here's a scene where it doesn't work for me - I'm using the latest version of Indigo for Mac.
Thanks in advance!
invisible to camera trouble.igs
(8.46 KiB) Downloaded 397 times
Post by Oscar J » Mon Jun 24, 2013 11:06 am
Did you manage to get anything out of it? :)
Post by OnoSendai » Mon Jun 24, 2013 8:01 pm
It's missing some meshes. Can you post the packed scene (PIGS) ?
Post by Oscar J » Tue Jun 25, 2013 3:08 am
It only contains an emitter (didn't want to upload my Koenigsegg) - which I can't hide from the camera.
invisible to camera trouble.pigs
(18.36 KiB) Downloaded 406 times
bubs
Post by bubs » Sun Jun 30, 2013 12:55 am
I tried to resume render from .igi and got the following message;
Scene parsing error: Error loading model 'C:\Users\Home\AppData\Local\Temp/dca29729-9db5-4716-bde0-a160803569fc.igmesh': Failed to open file 'C:\Users\Home\AppData\Local\Temp\dca29729-9db5-4716-bde0-a160803569fc.igmesh' for reading. (In element 'mesh', around line 3, column 9)
Indigo version: Indigo Renderer v3.6.16.2, Windows 64-bit build.
No metadata.
Please contact support@indigorenderer.com if you have any questions.
When I checked the Temp folder there was no .igmesh file at all... I've never had this issue before, and whilst the .igi file will open by itself in Indigo, once I do open it I can't even save it out as another image format, meaning the .igi is pretty much useless to me...
Am I doing something silly here?
