kepler
by kepler » Wed Jan 31, 2007 1:11 am
Hello, I can't figure out how can I render a semi-transparent material such as that of a lamp. See the image above:
It's a matter of IOR?
Sorry for the dumb question but I'm a very new user of Indigo (I'm using 0.6 version and Blender).
Kosmokrator
by Kosmokrator » Wed Jan 31, 2007 1:38 am
sorry my friend but with indigo 0.6 you cant simulate semi transparent materials or SSS like effects...try with 0.7 test 3....
kepler
by kepler » Wed Jan 31, 2007 3:57 am
Kosmokrator wrote:sorry my friend but with indigo 0.6 you cant simulate semi transparent materials or SSS like effects...try with 0.7 test 3....
Thank you... And sorry for the stupid question!
Kosmokrator
by Kosmokrator » Wed Jan 31, 2007 4:24 am
come on u are wellcome!!!That is the purpos of indigo comunity...helping each other! bye
drBouvierLeduc
by drBouvierLeduc » Wed Jan 31, 2007 5:10 am
Maybe you can try that :
Use a standard glass material like this (sorry poor quality) :
Then put
this texture on it, as a bump map. :
And you get something like this :
If you tweak the settings a little (specularity must be 0), I'm sure you can have a material close to the picture you posted.
(another example)
neepneep
by neepneep » Fri Feb 02, 2007 10:38 am
Why can't I apply bump maps to glass???
For example:
<medium>
<name>Material.scatter</name>
<ior>1.350</ior>
<cauchy_b_coeff>0.000</cauchy_b_coeff>
<precedence>10</precedence>
<uniform>
<value>0.5</value>
</uniform>
</medium>
<material>
<name>Material</name>
<glossy_transparent>
<exponent>500.000</exponent>
<internal_medium_name>Material.scatter</internal_medium_name>
</glossy_transparent>
<bump_map>
<uv_set>uv</uv_set>
<path>Glassbump.jpg</path>
<b>0.1</b>
<exponent>1.000000</exponent>
</bump_map>
</material>
I get the message:
SceneLoaderExcep: Found unexpected element 'bump_map' in element 'material'.
I tried making it a transparent specular material as well and same prob....
What in the name of f'ing Krishna am I doing wrong ???
kepler
by kepler » Fri Feb 02, 2007 9:02 pm
Thank you,
drBouvierLeduc! I will try that as soon as I can!
by CTZn » Fri Feb 02, 2007 9:52 pm
neepneep, the <bump_map> tag has to be a child the
material type definition, not of the tag <material> itself. If you refer to the doc, it is the child of the <diffuse> tag:
<material>
<diffuse>
<colour>0.8 0.8 0.8</colour>
<albedo_texture>
<uv_set>albedo</uv_set>
<path>checker.jpg</path>
<exponent>2.2</exponent>
</albedo_texture>
<bump_map>
<uv_set>bump</uv_set>
<path>bump_map.jpg</path>
<b>0.0001</b>
<exponent>1.0</exponent>
</bump_map>
</diffuse>
<material>
The fact is that I don't know if <glossy_transparent> supports bump mapping yet, but you may discover that quickly my friend
A rule of thumb is to remove what's unexpected and add what's expected by Indigo, as I said somewhere else you can trust it
