Indigo closes while rendering
12 posts • Page 1 of 1
thuleke
Post by thuleke » Fri Jan 12, 2007 3:59 pm
I have a problem. Indigo closes everytime I am trying to make a render. Sometimes one hour after initiation and sometimes more (four, five hours).
It does not show any messagge, just closes down and does it. I thought that was related to an error of the file but after some modifications that I have made, it has the same behavior. I tried to do it in other computer and did not work either. Help!
With other file is the same....Indigo Closes !!!
My computer is:
AMD ATHLON XP 2200+
1.34 GHZ Y 1GB DE RAM.
Thank you,
Daniel
Post by CTZn » Fri Jan 12, 2007 7:47 pm
Look here, if that was the file Indigo would not start render.
http://www.indigorenderer.com/joomla/fo ... php?t=1035
thuleke
Post by thuleke » Sat Jan 13, 2007 1:03 am
No, my PC don´t restart..my PC is ok.
Post by Zom-B » Sat Jan 13, 2007 2:00 am
sounds like a typical RAM issue for me...
Try to memtest your system, or simply just try to reduce Clock Speed of your memory, and check if Indigo keeps killing it self...
raising the voltage of your RAM (a little) is also common to stabilize the Memory...
arneoog
Post by arneoog » Sat Jan 13, 2007 2:52 am
sure that you don't mess with the Halt time option? :)
it should be set to -1 ...
Post by CTZn » Sat Jan 13, 2007 3:18 am
Oh yes I misread you sorry :)
Ever get the task manager opened while you are rendering, thought once the preprocess is done memory consumption is very stable AFAIK, should be something else, again... what arneoog said ? there is a log.txt in Indigo's folder, what says ?
thuleke
Post by thuleke » Sat Jan 13, 2007 3:35 am
Indigo closes after 10 minutes of rendering, 1 hour, 3 hours or 5 hours of rendering.
Halt time is ok, is -1
It´s a misterious !! :evil:
Post by CTZn » Sat Jan 13, 2007 3:54 am
thuleke
Post by thuleke » Sat Jan 13, 2007 4:29 am
Ok, the log.txt file says:
scene file path: 'C:\indigo\testscenes\imagine2.xml'
Using working directory path 'C:\indigo\testscenes'.
created world.
Loading Scene 'C:\indigo\testscenes\imagine2.xml'...
Post by CTZn » Sat Jan 13, 2007 5:09 am
Is that all ?
Weird, if that's not a memory issue I have no clue of what is happening... Please answer these questions:
1° What are the size of the file (optionally, how many triangles are there ?)
2° can you check in the Task Manager if ram hits a peak ?
3° t'es french Daniel ? (1GB DE RAM) :D
4° version of Indigo used ?
thuleke
Post by thuleke » Sun Jan 14, 2007 1:13 pm
Hi , the problem has been solved !!!! :D
I had to unable the "bidirectional" function.
Will the render quality be affected ?
Thank you!!
My answers:
1- 6 mb
2- 4900 kb
3- I m from Uruguay, South America :D
4-Indigo 0.6 and Blender exporter 0.5 y 0.6
qinjuehang
Post by qinjuehang » Sun Jan 14, 2007 5:55 pm
Bidirectional is buggy in v5. In v6, I don't have any issues...is that why?
