Brushed Titanium
13 posts • Page 1 of 1
Meelis
Brushed Titanium
Post by Meelis » Sat Nov 27, 2010 2:36 am
Hi :D
I'm experimenting with the brushed titanium material.
I used SmartDen texture from material Brushed Metal http://www.indigorenderer.com/materials/materials/55
Test scene is made by PureSpider
Depending on texture resolution (how much i have pixels per length unit) the result is very different.
In current case (1'st image) i tiled and mirrored 1024x1024 pixel image for preview scene to 3072x3072.
Higher resolution will give silky smooth look, too high even matt like look.
Click for full size
Scratched Metal X.igm
1'st Image igm
(1.11 KiB) Downloaded 220 times
Meelis
Re: Brushed Titanium
Post by Meelis » Sat Nov 27, 2010 6:52 am
Here is with default 1024 pix, pretty hard surface.
Click for full size
Next will be with 6x tiled (6144 pix)
Something in that scale (will post preview tomorrow or so but it looks already very stylish):
Click for full size
Meelis
Post by Meelis » Sat Nov 27, 2010 8:06 pm
Here is the 6144 pix
Yeah there is repeating pattern :?
Slave didn't work half of the time or so, reall speed was 185k S/sec
Click for full size
Doug Armand
Post by Doug Armand » Sat Nov 27, 2010 8:33 pm
Meelis wrote:Here is the 6144 pix
Click for full size
Well apart from the repeating pattern that is a pretty neat material.
Have you thought of using ISL for the pattern? I know next to nothing about how to use it but I have seen some pretty impressive results which should work perfectly for something like this
Doug
Doug Armand
Meelis
Post by Meelis » Sat Nov 27, 2010 9:24 pm
Thanks :D
I try to get ride of the repeating pattern.
Unfortunately i have no experience with ISL.
How was this texture generated, in PS, if so then how? So i generate higher resolution texture.
For example GIMP will crash if i try to generate higher resolution texture with many of the filters / scripts.
Doug Armand
Post by Doug Armand » Sat Nov 27, 2010 9:27 pm
Meelis wrote:Thanks :D
I don't know Gimp but in Pshop there is a filter called Offset which can often help in getting rid of repeating lines
Doug
Doug Armand
Meelis
Post by Meelis » Sat Nov 27, 2010 10:08 pm
Noted :D
Now i generate texture in GIMP with some random noise and then motion blur.
Applying motion blur for 6144x6144 pix image takes 10 min :shock:
and i have to find good noise density and motion blur length
(max length is 256 pix and that covers ~ 0,5 cm on last preview scene model) :?
Meelis
Post by Meelis » Mon Nov 29, 2010 12:31 am
Hey :D
After some experimenting i think that's final material.
You can download the material from
https://docs.google.com/leaf?id=0B1ETge ... ZTVk&hl=en
It's 40 Mb so i am not shure if i may upload to indigo MDB.
I made the texture in Gimp like that:
1) Exp map
* New image 6656 x 6656
* Random hurl 40%, repeat 1
* Motion blur, linear, length 128, angle 90
* Crop center out 6144 x 6144
* Little + contrast and unsharp mask
2) Bump map is just same image added 1 more unsharp mask 2/3/0 or was it 3/2/0 for more black scratches
Click for full size
NB! use correct scale to get same look of the material :!:
http://static3.nagi.ee/i/p/685/32/171332298a3ffd_o.jpg
dag
Post by dag » Mon Nov 29, 2010 2:52 am
Your exponent map does nothing with 10000 - 10005 values, and you could use the same map for bump and exp. I don't know why you would want a brighter exp map.
You could probably use a way smaller tiled map and never notice the difference with this kinda pattern.
10 min for motion blur? Photoshop used...... half a second, and it goes to 999!
This must be some new super tech shit.
Meelis
Post by Meelis » Mon Nov 29, 2010 3:14 am
I have no idea how to create such smaller tiled map that doesn't give pattern between mirrored edge. :?
Here u can see same render but exp map is same for bump map. There is noticable difference
Click for full size
I don't know much of exponent map parameters, i have to read over one more time :)
dag
Post by dag » Mon Nov 29, 2010 5:01 am
I mean use PACKED_1_Noise40Blur128Dark.png for both bump and exponent and you will get the same result, but this texture won't work well as exponent map anyway because of the tiny streaks and no larger details.
For exponent values, base value (c) is exponent for black parts, and for white parts it's c + b (multiplier). If you put 50 on c and 100 on b you get 50 exponent for black parts in the texture, and 150 for white parts.
Easy way to make this tileable is to do the noise and mblur stuff, then crop the edges if they didn't get equally blurred with the middle part. Dupe the layer, flip it vertically, then add a black white gradient mask from top to bottom. Tweak the gradient if the texture looks too mirrored.
Meelis
Post by Meelis » Mon Nov 29, 2010 6:22 am
Thanks for info dag
Is it correct then?
* 255 range values, they meet in middle.
* Black is c and it's 0 to ~ 127,5.
* White is b and it's ~ 127,5 to 255.
* All black values get same exponent = c = i used 10000
and not gradient as:
color 127,5 = exp 10000 / color 0 = exp 0 / color 1 = exp 78,43
* All white values get same exponent = c + b = i used 10005
color 255 = exp 10005 / color 127,5 = ~ exp 0
Or in middle will be white lowest exponent (0) and black highest exponent 10000 :?
I raised c value 10 x to 100 000, reflections got sharper.
I try to get it tileable without rising resolution, now this texture covers way too little 8)
Meelis
Post by Meelis » Mon Nov 29, 2010 8:06 pm
There is function in Gimp to make image seamless.
So i cropped 25% out from the corner, now the image is 3072 px and i made it seamless.
With bump map it's 14 Mb pigm, grayscale image would be 9,75 Mb but my grayscale image is converted back to rgb because a while ago Indigo didn't support grayscale png.
EDIT
:D :D Grayscale png works now, very nice
EDIT 2
Seamless 9,8 Mb 3072x3072 pix (7,5 x 7,5 cm / 2,9 x 2,9 inch) is now in Indigo MDB
http://www.indigorenderer.com/materials/materials/703
If u like more robust look scale it up :idea:
