Material Preview
OuiOui
Post by OuiOui » Tue Jan 08, 2008 5:04 am
Ohhhhhhh sorry .....
I must rebuild.... This dll is used by delphi while building for linux.. I must delete the link with this dll :?
OuiOui
Post by OuiOui » Tue Jan 08, 2008 5:13 am
dougal2
Post by dougal2 » Tue Jan 08, 2008 6:18 am
OK, it runs.
found a few bugs/problems:
1. Previewing blend materials doesn't work -- I assume because the dependant materials are not exported to the preview?
2. the "Indigo output" window keeps scrolling to the top, it's hard to actually
see the current output.
3. previewing materials with textures doesn't work.
4. exporting a .pigm doesn't include any textures.
OuiOui
Post by OuiOui » Tue Jan 08, 2008 9:24 pm
1°) you're rigth :)
2°) yes, it's a bit boring
3°) and 4°) Are you using "relative path" ? I'm using Absolute path and it works fine :)
dougal2
Post by dougal2 » Tue Jan 08, 2008 9:56 pm
yes, i always use relative paths with textures. in fact for .pigm, the paths need to be relative, or it doesn't work.
OuiOui
Post by OuiOui » Tue Jan 08, 2008 10:37 pm
dougal2 wrote:yes, i always use relative paths with textures. in fact for .pigm, the paths need to be relative, or it doesn't work.
Yes, I use "relative path" when I create PIGM file.
But i always use Absolute path in my scene (because I use indigo over a local netkork)
I will correct this today. Thanks for testing.
fishbowl
Post by fishbowl » Sun Jan 20, 2008 12:07 am
I get this error when I try to check the Preview tab:
Can't find : C:\Indigo\C:\Indigo\renders\im1200743681.png
It seems to double the Indigo path for some reason? I'd love to see that working, the rest is great. :)
OuiOui
Post by OuiOui » Mon Jan 21, 2008 7:58 pm
Can you post your "conf.ini" file ?
Maybe there is a error in that file.
fishbowl
Post by fishbowl » Tue Jan 22, 2008 1:27 am
Thanks, it looks okay, but I'll go ahead and post it.
I think it may be something to do with the fact that I have a multiboot system, and use the Subst command to set the H: drive as the C: drive. It's never affected anything else, but does that sound likely? :?
conf.zip
(275 Bytes) Downloaded 229 times
kwez
Post by kwez » Wed Jan 23, 2008 3:01 pm
hi,
nice app,
I had this problem (output from blendigo),
the xml reader chokes on this:
	<material> <!-- light or exit portal dummy material -->
		<name>posterEmit</name>
		<null_material/>
	</material>
if I move the comment before the <material> tag it works fine ;-)
thx
Philippe
OuiOui
Post by OuiOui » Thu Jan 24, 2008 3:45 am
fishbowl wrote:Thanks, it looks okay, but I'll go ahead and post it.
Your conf.ini files seems to be okay. I don't know if the "subst" command can affect my soft.
OuiOui
Post by OuiOui » Thu Jan 24, 2008 3:46 am
kwez wrote:hi,
nice app,
		<null_material/>
	</material>
thx
Philippe
I think the parser prefers when the comment are "alone" on the line.
Like this :
<material>
		<null_material/>
	</material>
I must try to find a better parser :?
