DEV-thread - Blendigo v0.7 - material-editor-exporter
Stur
Post by Stur » Sun Mar 18, 2007 10:02 pm
Splendid work on Blendigo. This script is very usefull. But, could you push the IOR max to 100 000 instead of 100 plz ? I can't make a perfect mirror with Blendigo.
Kyokutan
Post by Kyokutan » Sun Mar 18, 2007 10:29 pm
You must increase the exponent value to get a perfect mirror. Well...100 IOR maybe in'tt enough for an absolut full reflectiv surface...but 100000 would be an overkill. I think 100 ist enough.
zuegs
Post by zuegs » Sun Mar 18, 2007 11:15 pm
5OnIt wrote:Sorry but I don't know what I'm doing wrong. If I try to Render I get this error...
UnboundLocalError: local variable 'face' referenced before assingnment
I checked the possibilities for this error, and found that you must have an object in your scene that references a empty mesh (a mesh without faces).
So check in the console, just before error message, the last
exporting mesh "xxxx"
line where you find the name "xxxx" of your empty mesh.
Hope this helps, zuegs
zuegs
Post by zuegs » Sun Mar 18, 2007 11:35 pm
SMALL UPDATE
- phong exponent up to 1mio
- fixed animation export (reported by 5OnIt)
Sebastian
Post by Sebastian » Mon Mar 19, 2007 12:18 am
[req] !!!
Material-type: null !!!!
It would be very useful if u. Implement this type !!
zuegs
Post by zuegs » Mon Mar 19, 2007 12:41 am
Sebastian wrote:[req] !!!
hi sebastian,
It's in already... you can choose "null" material directly from "Blend" materials or you can create a blender-material with name "null" and it will export as null-material independent what you set as material-type.
Sebastian
Post by Sebastian » Mon Mar 19, 2007 1:14 am
Thx !! ^^
edit:
I foud a bug in the Dupli-export. ---> See Images.
One picture is before exporting other one after.
I used the same settings for both.
zuegs
Post by zuegs » Mon Mar 19, 2007 2:45 am
Sebastian wrote:I foud a bug in the Dupli-export. ---> See Images.
Hi Sebastian,
what dupli type u used? dupli-verts or dupli-faces? Implementation was focused on dupli-verts... ??????
Sebastian
Post by Sebastian » Mon Mar 19, 2007 2:52 am
I used Dupli-Verts and activate Rot.
zuegs
Post by zuegs » Mon Mar 19, 2007 2:53 am
can u post blend file please?
Sebastian
Post by Sebastian » Mon Mar 19, 2007 3:10 am
Here it is.
IndigoGraßTest.rar
(32.4 KiB) Downloaded 220 times
zuegs
Post by zuegs » Mon Mar 19, 2007 3:52 am
@Sebastian:
thanks for post.
This bug is due to an non-uniform scaling of the child object (cross-planes). To work around this just select the cross-planes and apply the object-transformation to the mesh by pressing Ctrl-A.
I will look if i can modifiy the exporter to properly support non-uniform-scaled objects for dupli-verts.
5OnIt
Post by 5OnIt » Mon Mar 19, 2007 5:36 am
K... I'll check and let ya know what I find
5OnIt
Post by 5OnIt » Tue Mar 20, 2007 5:46 am
That was it! Thanks for the help!
neepneep
Post by neepneep » Wed Mar 21, 2007 7:10 am
Hey Zuegs - I'm trying to export some frames as an animation but Blendigo keeps separating the meshes into one separate file, and then overwrites it with each frame exported.
Basically turning off the 'Sep Materials' option doesn't seem to make a difference when clicking 'ExportAnim'. :?
