MtI 1.0.6
dougal2
Post by dougal2 » Thu Jan 24, 2008 11:49 am
Hang on, I don't see why you need to go into blender at all from Maya. MtI should be generating a scene for you which you can render under wine.
If you are having problems exporting or rendering from Maya please let me know!!! I want this to work for you, I'll help you.
BTW, I'm posting this now from linux - finally got this sodding wifi driver to work. I'll have a look at running Maya and MtI under linux shortly.
Post by CTZn » Mon Jan 28, 2008 9:24 am
You kick ass Dougal !!!
Sorry for my last intervention, i'm very frustrated not to have a web connection at home and unfortunately that's likely to last.
dougal2
Post by dougal2 » Mon Jan 28, 2008 11:37 am
no probs dude.
vux
Post by vux » Wed Jan 30, 2008 12:52 am
I tryed it - very good - Especialy AdvancedSettingsWindow :D
some questions:
1) Problem with exit portals - I create exit portal but it is simple plane -
after export i opened scene in text editor and saw that is only mesh with name ExitPortal, but there are NO section <exit portal> :(
2) I working with metters - sow what i need to do to correct export scene - without change units in MayaPreferences?
dougal2
Post by dougal2 » Wed Jan 30, 2008 1:25 am
1) this may be a bug, I'll have a look.
2) Have you set Maya to use metres as your grid? It uses cm by default, which is fine.
You can use the GlobalScaleFactor (might be abbreviated to GSF, can't remember) setting in the AdvancedSettingsWindow (or, by it's proper name, mti_settings scriptnode) to change the scale factor that is used at export.
If Maya is set to metres, and you want Indigo to render metres, use 1.0
If Maya is set to centimetres, and you want Indigo to render metres, use 1.0
If Maya is set to centimetres, and you want Indigo to render centimetres, use 0.01
Basically, use the GlobalScaleFactor to adjust whatever 1.0 units are in Maya to metres in Indigo.
Hope that helps. :)
vux
Post by vux » Wed Jan 30, 2008 1:38 am
thanx
but GlobalScale Factor dont help men - i tried some variants like: 1.0, 0,1, 0.01, 10, 100, 1000 :D and etc - but it dont want to render correct :(
dougal2
Post by dougal2 » Wed Jan 30, 2008 2:08 am
How do you know it's not rendering correctly? Can you show some images of problems you're having ?
vux
Post by vux » Wed Jan 30, 2008 2:35 am
OK, Later I give you some pics
and
what about exit-portal. Is it work for you?
dougal2
Post by dougal2 » Wed Jan 30, 2008 2:37 am
Haven't tested it yet, as I'm still at work. I'll check later this evening.
dougal2
Post by dougal2 » Wed Jan 30, 2008 12:15 pm
REV 200
fixed exit portal bug.
.Zip package update to follow shortly... (tomorrow)
dougal2
Post by dougal2 » Wed Jan 30, 2008 12:38 pm
working exit portal
Phr0stByte
Post by Phr0stByte » Wed Jan 30, 2008 2:02 pm
dougal2
You friggin ROCK! I will test this when I can. While exporting the xml works well and then rendering with Indigo, any idea when render direct will work under linux? I will be glad to help you with any test ( or better yet, install VirtualBox and install a guest linux VM!) .
vux
Post by vux » Wed Jan 30, 2008 6:18 pm
THANX
About units:
I saw that if i start created scene in centimetres it work good
But if i create scene in metters and than change units to cm in prefs - it is bad
vux
Post by vux » Wed Jan 30, 2008 7:43 pm
dougal2
Where can i change IndigoFoldr/scene path?
if I save AttributeEditor preset it delete "\" char :(
dougal2
Post by dougal2 » Wed Jan 30, 2008 10:05 pm
vux: use forward slashes / in the path instead.
phrostbyte: renderdirect works in linux as of rev 199.
