Highly interesting thread to me !
I've been using Blender for quite a while, but I recently discovered Sketchup, and I might switch to SU, as I've realised modelling architecture in Blender takes a lot more time (to me) than in SU.
Well... I've got a question:
In Blender, you can position the sun where you want in your scene, but it doesn't appear to be the case in SU.
=> does it mean that you have to rotate your model in SU to position the sun correctly in your scene?
Here's an example:
- Let's imagine you have modelled a house using the default X/Y/Z axes' position.
- You set up your daytime (I don't know where you do this, but I'll have a look).
- If you want your sun to be, let's say, on the left-hand side of your model, what do you do? Do you have to rotate your model entirely? Or is there a way to position the sun?
(Thinking about it, it would actually sound like a more "realistic" approach to rotate the model and not the sky : in real life Earth and everything that's on it turns around the sun...
Many thanks in advance for your help !
