Indigo Renderer 2.4.3 Released
Re: Indigo Renderer 2.4.3 Released
We're working neo0; hopefully you'll look and notice we are answering a lot of forum questions. Consider joining the IRC channel if you need constant feedback.
... *drool*galinette wrote:This seems interesting... I work in a company with more than 300 desktops machines (dual core) which are almost never used at night... gaah
Etienne
I've ran into this before. If any of the RGB values of the SSS are 0, then the calculations freak out. Give them a check.everwind wrote:
I spotted another bug I've ever seen but I don't remember when : with some scene when you put a material to specular, the render never starts, it's only written "done 0.0000 samples 1.#INFO micro-seconds / sample ...", but Indigo uses 100% of the CPU and never render a picture.
Also if SSS Scattering Spectrum gain is to high samples drop to zero!Soup wrote:I've ran into this before. If any of the RGB values of the SSS are 0, then the calculations freak out. Give them a check.
Here to report a malfunction: I read someone gets crashes when enabling diffraction. I simply see no diffraction.
..I don't know if I'm doing anything wrong, but my camera is set to f/32 and I really think I should start seeing some glares :D
What does GLARE TECH say? :D:D:D
afaik you need to set it to f/8 to get some visual feedback, or even higher...
Pibuz wrote:Here to report a malfunction: I read someone gets crashes when enabling diffraction. I simply see no diffraction.
His f stop is much higher than f8. Weird.Zom-B wrote:afaik you need to set it to f/8 to get some visual feedback, or even higher...
The glare also depends on the aperture shape - If the aperture is circular, you won't see 'glare lines', but just a kind of fuzzy disc around your lights. Try using a non-circular aperture shape or an obstacle map.Pibuz wrote:Here to report a malfunction: I read someone gets crashes when enabling diffraction. I simply see no diffraction.
..I don't know if I'm doing anything wrong, but my camera is set to f/32 and I really think I should start seeing some glares![]()
What does GLARE TECH say?:D:D
F divided by 8 is higher than F divided by 32: http://upload.wikimedia.org/wikipedia/c ... iagram.svgStompinTom wrote:His f stop is much higher than f8. Weird.
FakeShamus
f/32 is a higher f/stop than f/8 but that means smaller aperture.
you get more diffraction with smaller aperture - http://www.cambridgeincolour.com/tutori ... graphy.htm
Ok, but you get more flare with a smaller aperature. You don't compare 'f divided by (number)', you compare the actual numbers. In that sense, 'shooting at a higher f-stop' means shooting at a higher number, ie. a smaller aperature. A wider aperature means a lower f-stop. Fact.Zom-B wrote:F divided by 8 is higher than F divided by 32: http://upload.wikimedia.org/wikipedia/c ... iagram.svgStompinTom wrote:His f stop is much higher than f8. Weird.
The fact is that I don't see any fuzziness or anything :)OnoSendai wrote:The glare also depends on the aperture shape - If the aperture is circular, you won't see 'glare lines', but just a kind of fuzzy disc around your lights. Try using a non-circular aperture shape or an obstacle map.
indigo_console.exe crash
I've noticed a bug (don't know is it a skindigo bug too).
It happens when I'm trying a material preview on indigo model (the other ones works) within sketchup. Preview in Material Editor works also.
windows 7 polish explanation
m.
Nazwa zdarzenia problemu: APPCRASH
Nazwa aplikacji: indigo_console.exe
Wersja aplikacji: 0.0.0.0
Sygnatura czasowa aplikacji: 4bc68dbc
Nazwa modułu z błędem: indigo_console.exe
Wersja modułu z błędem: 0.0.0.0
Sygnatura czasowa modułu z błędem: 4bc68dbc
Kod wyjątku: c0000005
Przesunięcie wyjątku: 00000000000e8e34
Wersja systemu operacyjnego: 6.1.7600.2.0.0.256.48
Identyfikator ustawień regionalnych: 1045
Dodatkowe informacje 1: b29a
Dodatkowe informacje 2: b29a8c5d7e67e1a0bcbaf603222445af
Dodatkowe informacje 3: e74e
Dodatkowe informacje 4: e74e82d3d6777527800a24c3738bdae8m.
- PureSpider
Hey!!! Is there anybody out there?
where is indigo 2.4.x for mac users?
We're testing a Mac build with some users, it's almost working. Expect a build today, or a very good explanation of why it's not there!
