ferns
- fenerolina
ferns
Hi everyone!
I've just uploaded a fern leaf material. So now you can make, with a bit of organisation, beautifull green pictures like these:
Hope you like..
Hope you like..
- ferns.png (491.42 KiB) Viewed 7125 times
- fern2.png (307.99 KiB) Viewed 7133 times
- fenerolina
Re: ferns
Yes they are! I knew you'd like it.
Notice the second one is a bit noisy and has some fireflys. Sorry for the noob question but how can I upload a bigger image for you to click on it and watch it full size.
- zeitmeister
Re: ferns
This is stunning, fenerolina!
- Polinalkrimizei
Re: ferns
Yes it is, thanks for sharing!
Your preview-pictures look photo-real, I wish I could see those in the matDb. Benn?
Re: ferns
Very nice material.
My only suggestion would be to add <step_blend>true</step_blend> to your blend materials. This will get rid of the fireflies.
- zeitmeister
Re: ferns
... but "step blend" kills gradients in blend maps, doesn't it?
Well, if provided.
Well, if provided.
Re: ferns
Correct, it makes the material either completely transparent or completely opaque, depending on the value of the blend map. Which can be good, because it gets rid of fireflies due to partial transparencyzeitmeister wrote:... but "step blend" kills gradients in blend maps, doesn't it?
Well, if provided.
- zeitmeister
Re: ferns
Thanks for the info!
- fenerolina
Re: ferns
I'm very glad you like it!
I'm afraid I don't understand when Ono says "add <step_blend>true</step_blend> to your blend materials" I know I have a lot of lacks in texturing, but could somebody explain it for me in more details?
Thank you.
Thank you.
- PureSpider
Re: ferns
Step blend is: "Everything below 50% white in the texture becomes 0% white (black) while everything above 50% white becomes 100% white"
That way gradients are killed but the rendering is more "efficent".
- fenerolina
Re: ferns
Thank you Purespider!
but my noobish question is where do I have to input this value in the texture?
Re: ferns
In that case, I think fenerolina wanted to achieve a semi-transluescent material, by blending a diffuser and a diffuse transmitter. I do not think you can do the same with step blend
Etienne
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
