Indigo 2.2.3, with Mat Editor beta 2
Doug Armand
Re: Indigo 2.2.3, with Mat Editor beta 2
Post by Doug Armand » Sun Oct 11, 2009 6:04 pm
If the Material editor is running and rendering and if I then run a Indigo render from Blendigo it will sometimes wait at the updating image stage till I stop the Material Editor rendering.
There can be other wierdness when both are running as well but nothing consistent.
Could just be my setup though :-)
any chance of a 64bit version?
psor
Post by psor » Mon Oct 12, 2009 6:28 am
@Doug
There is no need for a 64 bit version yet. Do you max out your
RAM while using the material editor? I don't think so. ;o))
take care
psor
remus
Post by remus » Mon Oct 12, 2009 7:25 am
64 bit indigo is quite useful though.
psor
Post by psor » Mon Oct 12, 2009 9:30 am
@remus
That's true, but since there is no change to the core yet you can use Indigo 2.2.1. ;)
take care
psor
Doug Armand
Post by Doug Armand » Mon Oct 12, 2009 3:56 pm
psor wrote:@Doug
take care
psor
I might - you should see the size of my texture maps! :^)
No I ask for it because having to install Indigo 32bit each time and then reinstall my 64 bit version is gonna get real annoying real quick.
Might be better if Ono offer the Material Editor as a seperate download.
psor
Post by psor » Mon Oct 12, 2009 4:12 pm
I feel ya! As a workaround you can open up the setup .exe with an archiver like 7zip
and extract the material editor without installing it. I dunno if it will work with the 64bit
version cause the editor needs 'QtNetwork4.dll' the 'config' directory and some files in
the 'data' directory. Another way would be to install into another directory ...
So good luck while waiting for Nick to set something up. ;o))
take care
psor
Post by OnoSendai » Mon Oct 12, 2009 4:16 pm
Next version will either have a 64 bit build, or the mat editor will be a separate download.
psor
Post by psor » Mon Oct 12, 2009 4:32 pm
OnoSendai wrote:Next version will either have a 64 bit build, or the mat editor will be a separate download.
Great, thank you! :D :D ;)
take care
psor
Doug Armand
Post by Doug Armand » Mon Oct 12, 2009 4:45 pm
Thanks Ono - either option would be great
Post by Pibuz » Tue Oct 13, 2009 1:26 am
Sorry guys: a little request.
Could it be possible to add a check in the GUI to add a realtime "render info overlay" string?
Post by OnoSendai » Tue Oct 13, 2009 9:54 am
Pibuz wrote:Sorry guys: a little request.
Yes, will add.
Post by neo0. » Tue Oct 13, 2009 9:57 am
Something wierd I noticed.. The material preview can actual be brighter with some materials than others.. Something about the materials absorbing energy?
Anyhow, this is probabaly really obvious but I can't find where you set the color of specular materials.. Shouldn't there be a diffuse channel?
Rendered through indigo material previews. I set it to nk data (chrome) It looks more like a diffuse.
Shouldn't the material editor have a "metal" type?
Rendered through skindigo previews.
Much more realistic
Post by OnoSendai » Tue Oct 13, 2009 9:59 am
neo0. wrote:Something wierd I noticed.. The material preview can actual be brighter with some materials than others.. Something about the materials absorbing energy?
The colour of specular materials is set by clicking on the medium (bottom left of GUI), and setting the absorption colour. Not sure about the brighter preview in some cases.
Post by neo0. » Tue Oct 13, 2009 10:11 am
Where can we adjust the gain (what the slider does in sketchup)?
Post by OnoSendai » Tue Oct 13, 2009 10:14 am
Neo: in your image from your post, when using a phong material, make sure to set the exponent to a good number. Right now it defaults to zero (which should be fixed).
