F-stop and linear tonemapping
I've made lot of test and I don't understand why but F-stop and linear tonemapping give change tonemapping!? Is it right?
- fstop 64.jpg (109.73 KiB) Viewed 4607 times
- fstop 32.jpg (186.13 KiB) Viewed 4607 times
- fstop 8.jpg (100.71 KiB) Viewed 4606 times
- Capture 2.JPG (114.85 KiB) Viewed 4606 times
- Capture 1.JPG (114.2 KiB) Viewed 4607 times
Re: F-stop and linear tonemapping
its correct. the lower the fstop the more light will reach the film
Thanksfused wrote:its correct. the lower the fstop the more light will reach the film
- PureSpider
But it hasn't been like that in older releases of indigo. What about not changing random stuff without letting the user know, Ono?
- pixie
If it wasn't as such before, it was wrong, therefore changing to right can only be the right thing to doPureSpider wrote:But it hasn't been like that in older releases of indigo. What about not changing random stuff without letting the user know, Ono?
of course it was like that before. it has always been like that
- PureSpider
Sooooo... Cindigo compensates the changed F-Stop? o.O
My pics never changed their brightness when I changed the F-Stop!
Tonemapping (other than linear) masks the change of illumination, I suppose.
Edit: Camera tonemapping without auto exposure (and no manual exposure adjustment) should not compensate.
probably because you used reinhard
- PureSpider
Just checked - and yes, I do use Reinhard in that scene I was talking about
Hey Jambert, I think the topic deserves a complement of information, but I am no expert in the field, hopefully my says will be also completed or corrected if necessary.
F-stop is an inverse value (1/n) wich refers to the width of the aperture for the shutter. Obviously, the bigger the divider n, the smaller the aperture.
F-stop = divider of aperture = divider of luminosity
Q: Is it correct to say that an F-stop of 32 means that the shutter aperture is 1/32th of its widest possible aperture?
Not quite, it means that the aperture is 1/32 of the focal length.... which is why low f-number telephoto lenses (large focal length) are expensive and massive - because the glass needs to be bigger.CTZn wrote:Q: Is it correct to say that an F-stop of 32 means that the shutter aperture is 1/32th of its widest possible aperture?
