OMG! They're made of glass!!Whaat wrote:Leaf Material:Code: Select all
<material> <name>D_Leaf_D</name> <phong> <texture> <uv_set>default</uv_set> <path>Leaf.jpg</path> <a>0.0</a> <b>1.0</b> <c>0.0</c> <exponent>2.2</exponent> </texture> <diffuse_albedo> <texture> <texture_index>0</texture_index> </texture> </diffuse_albedo> <ior>1.52</ior> <exponent> <constant>1000</constant> </exponent> </phong> </material> <material> <name>DT_Leaf_DT</name> <diffuse_transmitter> <texture> <uv_set>default</uv_set> <path>Leaf.jpg</path> <a>0.0</a> <b>1.0</b> <c>0.0</c> <exponent>2.2</exponent> </texture> <albedo> <texture> <texture_index>0</texture_index> </texture> </albedo> </diffuse_transmitter> </material> <material> <name>Leaf</name> <blend> <a_name>DT_Leaf_DT</a_name> <b_name>D_Leaf_D</b_name> <blend> <constant>0.5</constant> </blend> </blend> </material>
- pixie
No, they're made of a blend between diffuse transmitter and phong, which is a nice way to do a Leaf material. (For leaves with no thickness)
- pixie
OnoSendai wrote:No, they're made of a blend between diffuse transmitter and phong, which is a nice way to do a Leaf material. (For leaves with no thickness)
Sprite Test
(Actually, It's just the glass material with a higher IOR.)
- Liquid Preview2.png (827.32 KiB) Viewed 5155 times
Hey, it's funny I was thinking at leaf shaders yesterday ! Notably, leaves have a different tissues on each side, so I was thinking that a sort of a blend material, but normal based, would rock ! What is called a double-sided material (SketchUp has this by default I think). Could ISL do ?OnoSendai wrote:No, they're made of a blend between diffuse transmitter and phong, which is a nice way to do a Leaf material. (For leaves with no thickness)
For instance the top material could be phong+diffuse_transmitter, and downside OrenNayar+diffuse_transmitter. The double material would remain visually consistent if correct blend values are used for each material.
...Uh! Yessa, and I'd like Indigo to make coffee sometimes, when it's really cold, you know..
Just kidding mate (CTZn): I just couldn't resist, sorry!
I mean what I said Pibuz ! I don't know if we can query normals direction using ISL but that might be enough to make that double sided material a reality...
I made 2 new animation tests.
Grass
http://www.youtube.com/watch?v=obUy8P8FoMg
Particles
http://www.youtube.com/watch?v=3q86ZQ_bF44
Grass
Particles
Great Suv, thanks for your grass explanations, the best one I ever seen
Shouldn't it be lower IOR? Glass is about 1.5 when water (or Sprite...) is about 1.3.Godzilla wrote:Sprite Test(Actually, It's just the glass material with a higher IOR.)
also his meniscus is very flat, his straw is droopy and the carbonation is like club sodaSilmä wrote:Shouldn't it be lower IOR? Glass is about 1.5 when water (or Sprite...) is about 1.3.Godzilla wrote:Sprite Test(Actually, It's just the glass material with a higher IOR.)
- Borgleader
All valid points, the liquids IOR should be lower than that of glass, bubbles should in my opinion be more to the sides and maybe have clumps of them at the bottom (where the edge is). And straighten that straw!dmn wrote:also his meniscus is very flat, his straw is droopy and the carbonation is like club sodaSilmä wrote:Shouldn't it be lower IOR? Glass is about 1.5 when water (or Sprite...) is about 1.3.Godzilla wrote:Sprite Test(Actually, It's just the glass material with a higher IOR.)
I made an architecture!
- render2.jpg (220.06 KiB) Viewed 4749 times
one of your pillars is floating Ono
The floor on the right side looks strange...
I try to find out what is the special story behind this image... master Ono posting renderings without showing new features... can't be!!!
Maybe some new sun system... the shadow on the let looks quite not so sharp (more realistic) like I remember Indigos sun shadows to be... hmmmm
