Post by pixie » Sat Jul 25, 2009 9:36 am
Whaat wrote:Leaf Material:
<material>
			<name>D_Leaf_D</name>
			<phong>
				<texture>
					<uv_set>default</uv_set>
					<path>Leaf.jpg</path>
					<a>0.0</a>
					<b>1.0</b>
					<c>0.0</c>
					<exponent>2.2</exponent>
				</texture>
				<diffuse_albedo>
				<texture>
				</texture>
			</diffuse_albedo>
			<ior>1.52</ior>
			<exponent>
		<constant>1000</constant>
			</exponent>
		</phong>
		</material>
		<material>
			<name>DT_Leaf_DT</name>
			<diffuse_transmitter>
				<texture>
					<a>0.0</a>
					<b>1.0</b>
					<c>0.0</c>
				</texture>
				<albedo>
				<texture>
				</texture>
			</albedo>
			</diffuse_transmitter>
		</material>
		<material>
			<name>Leaf</name>
			<blend>
				<a_name>DT_Leaf_DT</a_name>
				<b_name>D_Leaf_D</b_name>
				<blend>
					<constant>0.5</constant>
				</blend>
			</blend>
		</material>
OMG! They're made of glass!! :shock:
Post by OnoSendai » Sat Jul 25, 2009 6:23 pm
No, they're made of a blend between diffuse transmitter and phong, which is a nice way to do a Leaf material. (For leaves with no thickness)
Post by pixie » Sat Jul 25, 2009 6:25 pm
OnoSendai wrote:No, they're made of a blend between diffuse transmitter and phong, which is a nice way to do a Leaf material. (For leaves with no thickness)
:mrgreen: Indeed... my remark was only due to the ior's material, if it was really to be some sort of glass it had to be pure specular
Godzilla
Post by Godzilla » Sun Jul 26, 2009 1:56 am
Sprite Test :o (Actually, It's just the glass material with a higher IOR.)
Liquid Preview2.png (827.32 KiB) Viewed 5142 times
Post by CTZn » Sun Jul 26, 2009 4:06 am
Hey, it's funny I was thinking at leaf shaders yesterday ! Notably, leaves have a different tissues on each side, so I was thinking that a sort of a blend material, but normal based, would rock ! What is called a double-sided material (SketchUp has this by default I think). Could ISL do ?
For instance the top material could be phong+diffuse_transmitter, and downside OrenNayar+diffuse_transmitter. The double material would remain visually consistent if correct blend values are used for each material.
Post by Pibuz » Sun Jul 26, 2009 11:56 pm
...Uh! Yessa, and I'd like Indigo to make coffee sometimes, when it's really cold, you know..
:D :D :D
Just kidding mate (CTZn): I just couldn't resist, sorry! :D
Post by CTZn » Mon Jul 27, 2009 12:42 am
:roll: :P :wink:
I mean what I said Pibuz ! I don't know if we can query normals direction using ISL but that might be enough to make that double sided material a reality...
Post by suvakas » Mon Jul 27, 2009 2:22 am
Jambert
Post by Jambert » Mon Jul 27, 2009 5:47 am
Great Suv, thanks for your grass explanations, the best one I ever seen :shock:
Silmä
Post by Silmä » Wed Jul 29, 2009 8:14 am
Godzilla wrote:Sprite Test :o (Actually, It's just the glass material with a higher IOR.)
Shouldn't it be lower IOR? Glass is about 1.5 when water (or Sprite...) is about 1.3.
dmn
Post by dmn » Wed Jul 29, 2009 2:54 pm
also his meniscus is very flat, his straw is droopy and the carbonation is like club soda :mrgreen:
Post by Borgleader » Wed Jul 29, 2009 2:58 pm
All valid points, the liquids IOR should be lower than that of glass, bubbles should in my opinion be more to the sides and maybe have clumps of them at the bottom (where the edge is). And straighten that straw! :wink:
Post by OnoSendai » Fri Jul 31, 2009 5:59 pm
I made an architecture!
WytRaven
Post by WytRaven » Fri Jul 31, 2009 6:41 pm
one of your pillars is floating Ono ;) :lol:
Post by Zom-B » Fri Jul 31, 2009 7:12 pm
The floor on the right side looks strange...
I try to find out what is the special story behind this image... master Ono posting renderings without showing new features... can't be!!!
Maybe some new sun system... the shadow on the let looks quite not so sharp (more realistic) like I remember Indigos sun shadows to be... hmmmm
