I made my own setup base on what i saw in your render (replacing the sphere with suzanne, cant help it
PLEASE HELP!!!!
- Borgleader
Re: PLEASE HELP!!!!
I'm not sure how big an emerald usually is but I think in that case scale may be the issue, I'm guessing the bigger your object is the darker it'll get until it becomes opaque.
). and I am able to see through it, of course its not very clear but the material is definitely transparent.
Re: PLEASE HELP!!!!
thanks ill try it with different sized modles
- Borgleader
Re: PLEASE HELP!!!!
Actually if you model it to the size it should be in real life you should be fine. I do believe the default Blender unit = 1 meter. So by taking that into account when you're modeling things should turn out fine.
Re: PLEASE HELP!!!!
Off-topic, but Borgleader, your signature seems to be slightly out of date
(When the hell are we going to have another competition? I'm dying to.. be.. competitive?)
Re: PLEASE HELP!!!!
New error message(Error: SceneLoaderExcep: ObjectExcep: No such uv set 'UVTex' (In element 'model', around line 17447, column 5) heres a screenshot
- 5.jpg (218.11 KiB) Viewed 3833 times
Re: PLEASE HELP!!!!
the imported material you took from the MatDB has <uv_set> to uv.
Change this value in the igm to default and it should work
- Borgleader
Re: PLEASE HELP!!!!
@3dGeek: ZomB beat me to it. Its simpler to call your Blender uvset "uv" instead though, i think.
@Godzilla: fixed
@Godzilla: fixed
Re: PLEASE HELP!!!!
@borgleader-nice new sig, lol
