SmartDen
Post by SmartDen » Thu Oct 02, 2008 4:48 am
zsouthboy wrote:I love it, Smart. Looks good!
Thanks. But i'm not very happy with modeling and lighting. maybe i'll done it once...
Check normals, dude!
MadSwede
Post by MadSwede » Thu Oct 23, 2008 10:19 pm
Hurray for the site being back up!
Just thought I'd share this unfinished project. I set up the scene in a stupid way and there's a bunch of things I changed in the pose and model since this rendering. Nevertheless, I'll probably never finish this so a simple render will have to do.
As for any comment: 'What hitchhiker? What guide? Marvin who?'
Some 4000 samples. Can't remember.
Post by Zom-B » Thu Oct 23, 2008 11:33 pm
Over the Days the site was down I also tried to do something new andfinaly started to play around with Bodypaint, for a simple Kitchen-close-up scenario I got in my mind...
The Oranges aren't as good as they could be...contrast in my source images for the texture was lacking :/
Also I wait for the next Cindigo version for proper Blend fix so I could get better contrast between reflecting & non reflecting areas...
The Applecutter isn't finished jet, but I tried for some shading so far.... the plastic cap uses glossy transparent material with SSS and an exponent Map for the "dirt"
3 slightly different texture versions, all done in Photoshop, based on the middle original Bodypaint output...
Still a lot of fireflys around... a phong issue??
Hellstorm
Post by Hellstorm » Fri Oct 24, 2008 12:14 am
Yeah I know it looks a bit like fanta, but my aim was just to try a dielectric interface with liquid :P
Post by PureSpider » Fri Oct 24, 2008 12:16 am
fanta was my idea! stop stealing my genius! :P :D
looks good though ;)
Hellstorm
Post by Hellstorm » Fri Oct 24, 2008 12:34 am
As long as I don't put a Beck's Texture onto it, its okay i think :P
Post by OnoSendai » Tue Oct 28, 2008 1:22 am
Messing with code, and making an example render for the Clay material.
Model from http://www-graphics.stanford.edu/data/3Dscanrep/
Post by Zom-B » Tue Oct 28, 2008 1:36 am
oh, nice!
looks much better than the "old" Oren Nayar :)
Post by OnoSendai » Tue Oct 28, 2008 1:58 am
Haven't changed the Oren-Nayar code :)
Onfame
Post by Onfame » Tue Oct 28, 2008 5:19 am
awesome :shock:
Post by CTZn » Tue Oct 28, 2008 6:31 am
1.1.14 yummy !!!
BTW Ono is this oren-nayar or a isl shader ? I don't understand neither what you meant by "Messing with code"... That's the same shader you posted in the db right ?
Post by Kram1032 » Tue Oct 28, 2008 7:12 am
O.o those last few are great :D
If you didn't change the oren-nayar code, where's the code-messing part then?
Post by OnoSendai » Tue Oct 28, 2008 1:49 pm
Wait until next release :)
dmn
Post by dmn » Tue Oct 28, 2008 2:55 pm
Here are some test renders from my attempt at the small objects competition long ago.
Hellstorm
Post by Hellstorm » Tue Oct 28, 2008 10:03 pm
Latest test for some kind of rough anisotropic gears.
Mechanic Wheels
