Shader tests
Post by CTZn » Tue Jul 29, 2008 10:20 am
It sure looks great !
Post by Borgleader » Tue Jul 29, 2008 11:11 am
CTZn wrote:It sure looks great !
+1
And...how do you....map a procedural? I mean, in the 3d editor, how do you map the fbm?
Grimm
Post by Grimm » Tue Jul 29, 2008 11:51 am
Borgleader wrote: And...how do you....map a procedural? I mean, in the 3d editor, how do you map the fbm?
I'm not exactly sure what you mean by "map" the fbm, but I will take a stab at it. :) Fbm's are just random noise so you don't really know what you are getting until you render an image. You can adjust the texture by either scaling or translating the terms you feed into the fbm. This has the effect of resizing or moving the fbm and the resultant textures on the mesh. I hope this helps.
Grimm
Big Fan
Post by Big Fan » Tue Jul 29, 2008 11:54 am
that brushed look is very nice ono
I think I will build that shader and vector direction into the specular reflectivity exporter settings just for that - very handy for Solidworks materials...
the previous egg shell/dimpled look is nice too - might borrow that as well
keep the examples coming 8)
EDIT:ok done that now when is 1.1.8 coming so I can try it? :lol:
eman7613
Post by eman7613 » Tue Jul 29, 2008 5:07 pm
OnoSendai wrote:
eman7613 wrote:i do belive the syntax would benifit greatly from operators :lol: :shock:
for anyone used to coding in java's horrid bigdecimal *raises hand*, this looks very familure :roll:
That's what you get for using a language without operator overloading (Java) :)
its my one complaint, but its okay, i made my own*
*j/k its just a math parser
Yes i know, my spelling sucks
Post by Kram1032 » Mon Aug 04, 2008 12:45 am
Grimm wrote:@Kram - Thanks, this has been a challenge that's for sure. :) Is this test more to your liking?
Yeah, those two last ones are great :D
First is pretty boneish and second pretty marblish :D
Anisotrophy :D Cool!
Post by fused » Tue Aug 12, 2008 2:13 am
ok,,, its hard to compete with such impressive shaders,,,
here are two very simple (you see, very very simple) gradient shaders, hope someone will find them useful:
<albedo>
	<shader>
		<shader>
			<![CDATA[
			# 2D gradient shader U
			def eval(vec3 pos) vec3 :
				vec3(
					doti(getTexCoords(0))
		</shader>
	</shader>
</albedo>
<albedo>
	<shader>
		<shader>
			<![CDATA[
			# 2D gradient shader V
				vec3(
					dotj(getTexCoords(0))
		</shader>
	</shader>
</albedo>
thnaks to zomb for rendering!
Post by fused » Tue Aug 12, 2008 2:49 am
3d gradient in z direction this time. a tiny bit more complex.
guess this can be quite useful :)
<albedo>
	<shader>
		<shader>
			<![CDATA[
			# 3D gradient shader Z (up)
				vec3(
					div(mod(dotk(pos),0.6),0.6)
		</shader>
	</shader>
</albedo>
<albedo>
	<shader>
		<shader>
			<![CDATA[
			# 3D gradient shader Z (up) with center = 0.5
				vec3(
					div(mod(add(dotk(pos),div(0.6,2.0)),0.6),0.6)
		</shader>
	</shader>
</albedo>
again, thanks to zomb for rendering.
Post by CTZn » Tue Aug 12, 2008 2:58 am
Still cryptic but very usefull, fused, plz keep them coming !
cpfresh
Post by cpfresh » Tue Aug 12, 2008 9:20 am
the z up gradient is awesome, thanks for sharing fused!
Post by Whaat » Tue Aug 12, 2008 9:56 am
thanks for sharing this. It is useful to know what works. I have had lots of problems getting shaders to work.
Deus
Post by Deus » Tue Aug 12, 2008 12:04 pm
To be honest its pretty simple (if you can program to start with)
Anyone know if you can declare variables yet? I mean performance AND readability would increase tremendously
Compare:
<albedo>
   <shader>
      <shader>
         <![CDATA[
            vec3(
               div(mod(add(dotk(pos),div(0.6,2.0)),0.6),0.6),
      </shader>
   </shader>
</albedo>
to:
<albedo>
   <shader>
      <shader>
         <![CDATA[
            float color = div(mod(add(dotk(pos),div(0.6,2.0)),0.6),0.6)
            vec3( color, color, color )
      </shader>
   </shader>
</albedo>
And why the Double shader tags? Nesting gone nuts tbh
Post by OnoSendai » Tue Aug 12, 2008 12:14 pm
No, you can't declare variables.
However you could factor out the colour computation into another procedure.
Actually, in this case, you can use the scalar vec3 constructor vec3(real x) vec3.
The double shader tags are there to draw a distinction between the type, and value of the albedo material parameter.
Post by CTZn » Tue Aug 12, 2008 12:40 pm
it would be cool to declare textures and shaders globally (keeping using the index thing) instead into a material, so they can be called by any of them while delared once only. Maybe this could apply for constant definitions too ?
This idea comes along with the one of a database for constant maybe, and shaders, and with manual coding of shaders. It does not make much sense in regard with the generic scene exporting process.
Post by fused » Tue Aug 12, 2008 6:48 pm
OnoSendai wrote:Actually, in this case, you can use the scalar vec3 constructor vec3(real x) vec3.
i have completely overlooked it! :o (edited the shaders now using this)
Deus wrote:To be honest its pretty simple (if you can program to start with)
ahhh thanks? i told you so :)
@ono:
can you give me a quick example on how if() works? how can i, for example check if a value is > 1?
