Downloading software
9 posts • Page 1 of 1
sintra
Post by sintra » Wed Nov 15, 2006 11:07 pm
Hello,
I am currently trying to download the software (Version 6). How long does this normally take because it seems to be taking forever i started downloading it about 4 hours ago and its still not finished. Is this normal ?
Thanks
Darren Goodwin
Post by OnoSendai » Wed Nov 15, 2006 11:31 pm
No.. it's only about 2MB big, try again :)
sintra
Post by sintra » Thu Nov 16, 2006 12:13 am
Thanks for reply
Already tried that. any more suggestions.
Darren
zsouthboy
Post by zsouthboy » Thu Nov 16, 2006 2:53 am
It's working fine for me.
Took 2 minutes at the most.
Check your net connection.
sintra
Post by sintra » Thu Nov 16, 2006 3:26 am
Thanks for reply zsouthboy.
When i download the zip file and extract the files i have been selecting indigo.exe file is this correct or should i be selecting something else.
Thanks
Darren
Kachu
Post by Kachu » Thu Nov 16, 2006 3:35 am
Extract the entire folder. You should be able to double click on Indigo.exe and have it run one of the sample scenes right out of the box er zip. There is no installer for Indigo if thats what you were thinking.
sintra
Post by sintra » Thu Nov 16, 2006 3:45 am
When i double click indigo.exe it brings up 2 boxes one with a image of some round pieces of glass and the other a black box with a load of commands in it.
Sorry to be a pain but could you talk me through how you set it up.
Darren[/img]
Phil
Post by Phil » Thu Nov 16, 2006 3:52 am
Hello sintra,
Welcome here.
I suggest you to first read the FAQ using indigo.
Then read the tutorial blender and Indigo.
They explain the most things about Indigo, you can post after reading this with more precise questions.
Regards, Phil
Kachu
Post by Kachu » Thu Nov 16, 2006 8:10 am
When you double click Indigo you are loading the renderer. Indigo is a renderer not a modeling program. Indigo loads inifile.txt to load its settings and to select the scene that it will render. The scene is an xml file generated by one of the indigo exporters.
I recommend you check out this to get the feel of setting up the renderer unless you have a different modeling program. (There are multiple translations) (This is the blender tutorial that Phil is talking about)
http://www.indigorenderer.com/blender_tut/
I hope I haven't offended you by oversimplifying some rather technical data. If so I sorry.
Users browsing this forum: No registered users and 230 guests
