Maxigo 1.15.7-Test1a [update-09.07.08]
- Doug Armand
- Kosmokrator
hello suv i found an bug or a brocken feature?:
when i try to use reg rendering the indigo show me this erros msg and quiting after ok!!may u know it but just ..i refer it
great work man i start again my projects with this update......
oohh and thnx for the bump values
- err.jpg (62.51 KiB) Viewed 8398 times
- Doug Armand
So far only that one has caused a problem
Tried a few of the others and they seem ok. Will download it again and give it another go - and yes Max 9
Doug
Doug Armand
Doug Armand
- Doug Armand
- Kosmokrator
well doug i download the material too and its works just fine in my machine.......
thas makes things even strange....
- Doug Armand
A feature request.....
I know this isn't the place but any Idea if you could add the option to slect which viewport to render? I use a dual monitor setup and am constantly forgetting to make the camera view active.... file this feature request under 'UI implementation for stupid users'
Doug
Doug Armand
Doug Armand
Maybe a bad download, that caused a 0KB pigm file?Doug Armand wrote:K juts downloaded and tried again and.... it works![]()
Who knows what went wrong?
But anyway, seems like the dotNet stuff is working. I can then start using it in other areas as well. I'm thinking about rewriting the preview material too, cause at the moment it works quite "randomly".
- Kosmokrator
Get the latest update from the first post of this thread. The broken edge problem should be fixed now. It was my mistake and not Indigo'slady D wrote:there is someone that ago a test?
and post the setting? sorry sorry![]()
Rendered with Test1a:
- displacement.jpg (176.15 KiB) Viewed 8324 times
- Kosmokrator
