displacement tests thread
drBouvierLeduc
Post by drBouvierLeduc » Fri May 30, 2008 6:50 am
One last test with that elephant rock scene.
I wanted to try displaced grass. Obviously, the mesh is not subdivided enough, but if I put a higher subdivision level : kaboooom ! Indigo crashes.
I will try a last test with a more subdivided mesh (you know, by splitting it in several parts), but anyway I think for grass, instanced mesh is a better solution.
grass ? not sure
tungee
Post by tungee » Fri May 30, 2008 6:55 am
One word:
Stunning! :shock:
cpfresh
Post by cpfresh » Fri May 30, 2008 7:12 am
yea! really awesome dr!! :D
Phr0stByte
Post by Phr0stByte » Fri May 30, 2008 7:51 am
Can't wait for this to go into a linux build... (Hint, hint, Ono)
To me, this is a MAJOR release
MESCH973
Post by MESCH973 » Fri May 30, 2008 8:36 am
absolutely GREAT thread! :shock: :shock: :shock:
drBouvierLeduc
Post by drBouvierLeduc » Fri May 30, 2008 9:06 am
Ok, my mistake : decent grass is possible with accurate subdivision level.
displaced grass attempt
alex22
Post by alex22 » Fri May 30, 2008 9:11 am
What did you change? looks very nice now.
Post by OnoSendai » Fri May 30, 2008 9:13 am
nice!
pxl666
Post by pxl666 » Fri May 30, 2008 9:16 am
sweet jesus! its amazing! how does the grass map looks like? whats the polycount and mem usage ? rendertime??
pls pls pls!!!
Post by Kram1032 » Fri May 30, 2008 9:45 am
awesome tests, amazing!
drBouvierLeduc
Post by drBouvierLeduc » Fri May 30, 2008 10:00 am
I can't post the entire map because it's too big, so here's what it looks like (in the squares the real size). For displacement I used a carpet map.
I guess it would still look a bit better if I could push subdivision a bit further (it's at level 6), but then again I'm limited by memory crashes.
Memory usage was between 1-1,5 Gb, rendered for about 25mn on a core2duo.
pxl666
Post by pxl666 » Fri May 30, 2008 10:52 am
i wonder how this grass looks in a closeup - how does a single leaf looks like...
would u like to render a macro shot?
zsouthboy
Post by zsouthboy » Fri May 30, 2008 12:25 pm
Dr, that looks GORGEOUS.
pxl666
Post by pxl666 » Fri May 30, 2008 6:36 pm
cant wait to see updated blendigo!!!
Stur
Post by Stur » Fri May 30, 2008 9:16 pm
That's just incredible Dr ! :shock:
