So..this time it isn't really Indigo that's the problem.
11 posts • Page 1 of 1
Photoguy
Post by Photoguy » Thu Mar 13, 2008 7:38 am
I'm having trouble with textures, when i apply a texture on a plane or circle or anything it only textures in strips.
See attached photo.
Labello
Post by Labello » Thu Mar 13, 2008 7:46 am
did u apply a uv-mapping? that can be the only reason why your models deliver such strange results
Photoguy
Post by Photoguy » Thu Mar 13, 2008 7:49 am
Yeah, i guess so, i applied it UV image editor.
And pressed "tex face" on materials (don't know if it's necessary with Indigo)
But every time it comes up with this!
Labello
Post by Labello » Thu Mar 13, 2008 8:00 am
and u are shure that your mapping is correct?
Photoguy
Post by Photoguy » Thu Mar 13, 2008 8:03 am
Yeah, i didn't see anything wrong with it.
I might import this scene to a new file and try it like that.
Labello
Post by Labello » Thu Mar 13, 2008 8:29 am
and why dont u simply extrude the plane a tiny little bit?
Vanessa07
Post by Vanessa07 » Thu Mar 13, 2008 10:14 am
You must select uv in "map to" I think
Photoguy
Post by Photoguy » Thu Mar 13, 2008 6:18 pm
Ok, i tried a different texture and that fixed it!
I don't know why it was doing that, i guess it was just stupid...oh well.
Photoguy
Post by Photoguy » Thu Mar 13, 2008 11:25 pm
...Or at least i thought it was fixed, but it really isn't.
As the render cleared i realized that now the texture is fine, it's just the bump map that is tiling wierd.
here is a render, it's at 147 samples, so it's not too clear, but it should do.
Qwaszt
Post by Qwaszt » Fri Mar 14, 2008 3:30 am
Hi Photoguy,
I ran into the same problem and probably the answer to your problem is in this thread:
http://www.indigorenderer.com/joomla/fo ... em&start=0
Kram1032 made it very clear.
Hope it helped.
Photoguy
Post by Photoguy » Fri Mar 14, 2008 8:22 am
Hey thanks Qwaszt that helps!
