My first scene.
My first scene.
Okay, quickly: I started messing around with both Blender and Indigo for the first time this past weekend. Before that, I had some very limited experience with POV-ray. This is my first scene, and I would like to keep it relatively simple (surprise). this does not mean that it has to be tacky or too lame. Anyway, this is just the first version, resized so that it doesn't incur the dreaded bottom scroll bar.
</beg-for-mercy>
I would be grateful if I could get some advice as far as simple additions/tweaks that would be noob friendly. I have a new version baking/cooking/sautéing now. Basically this will be the same, but with a UV-mapped (I can't believe I finally figured it out!) note, some absorption in the glass, and actual window frames (2!). To avoid confusion, those two blue things started out as reference objects, but now they are *trying* to be racquetballs.
</beg-for-mercy>
- room_0.3tm_small.png (438.58 KiB) Viewed 20246 times
Thank you for the comments! Being the new kid on the block, any comments I can get mean a lot.
Yeah, I changed them a little; I found a picture of a racquetball from Google and just sampled that to get my HSL. Maybe I should just tweak the saturation down a little. It won't be changed in the next version- I just took a peek at the one I have rendering right now and I'm very happy with the way the paper is looking.Kram1032 wrote: Did you actually change your spheres' mats? They look pretty much the same...
Now, Stur gave you the same advice xD
Alright, here's the slightly anticipated (by me) fourth version of this scene. I think next I will just totally redo the modeling, so any suggestions would be much appreciated. Thoughts about the tonemapping?
Dang, that paper looks good
Edit: resized image as I have a newer version now.
- room_0.4.png (447.94 KiB) Viewed 19933 times
Tonemapping doesn't look bad to me. The paper looks good but also in balance on its fold, wich is unrealistic.
For wine glasses my two cents would be to induce same wavyness in revolve profile, or the very regular shape of caustics could be unrealistic also.
And on caustics, I'm not sure you used bidir, did you ?
the sheet looks great, Indeed
(As CTZn said, you should change the balance
Btw. I don't know, what you used for your paper, but it's colour would be correct at 0.851 grey
(someone wrote, the measured value would be about 215 grey. Converted to a normalized value, it equals 0.85098039215686274509803921568627)
I'm not sure, as it's quite blurry, back, there, but it looks like the back leg, that you can see the whole way down, slightly floats...
I really like the simplicity of this scene in that it hints at complexity (the reflection in the glass) without overtly showing it off. Its as if the viewer knows there's a lot more going on than a table with simple items on it, but they really can't put their finger on why. I've become so used to the amazing results that indigo just naturally achieves now that I've resorted to scouring an image to find something to nitpick rather than just sitting back and enjoying the stunning realism. The quality of this renderer has forced its artist-users to move on from messing with the basics and face up to the myriad of infinitessimal details that make artwork truly great.
yttrium88, for having just tinkered with these apps for a few weeks, you've come a long way. Keep at it! Looking forward to enjoying the results of your labor!
-mzungu
"The fear of the Lord is the beginning of wisdom" - Solomon
Thank you all for the comments. I hope you will get to see this room evolve somewhat rapidly as I am on the fun part of the learning curve right now.
That would be sweet, but I really don't think I have the modeling skills yet, at least not for the photographer.
As I figure out how to make this darn UV thing work, the room is sort of changing. My next object might be a thick woven mat. Nothing too showy, if there is a sort of easy way to do this, I would appreciate the help.
Thanks
Nathan
Oh, an here is the newest render, I swapped the table out and put that pot over by the edge. I hope this doesn't all seem like I'm "thinking out lout" but things are just changing so quickly as I learn more. By the way, can anyone read the note?
I don't usually use a lot of 'Emoticons', butkadajawi wrote:Ps: I have an idea... what about seeing the camera and the photographer in the reflections?
Thanks
Nathan
- New tabletop, new floor material
- room_0.5.png (1.57 MiB) Viewed 19937 times
